MVPN in between NX-OS and IOS
sesoerensen
I'm having an issue configuring mvpn in between a N7K and IOS Router.
On the IOS router, i'm seeing this error message:
DT-4-INCOMPATIBLE_TUNNEL_TYPE: Incompatible tunnel type in BGP update router_id:10.16.32.1 RD:10.16.32.1:13 type:1 tunnel_type:4; local tunnel_type:0.
10.16.32.1 is the router-id of the N7K.
I have a source connected to the IOS router, and a reciever connected to the N7K.
the mroute *is* installed into the mroute table.
I haven't been able to find any way to adjust the "tunnel type " for mvpn's on either the N7K's or the IOS Routers.
Unicast routing is working as expected.
Any pointers would be highly appriciated
N7K:
Software
  BIOS:      version 2.8.0
  kickstart: version 6.1(4)
  system:    version 6.1(4)
  BIOS compile time:       06/09/12
  kickstart image file is: bootflash:///n7000-s2-kickstart.6.1.4.bin
  kickstart compile time:  12/25/2020 12:00:00 [05/16/2013 03:52:57]
  system image file is:    bootflash:///n7000-s2-dk9.6.1.4.bin
  system compile time:     3/11/2013 23:00:00 [05/16/2013 04:57:07]
IOS:
System returned to ROM by reload at 11:51:18 UTC Tue Sep 24 2013
System image file is "flash:/c3900e-universalk9-mz.SPA.153-3.M.bin"
Søren
The issue appears when there's a mismatch in the type of multicast for the MDT - ASM vs. SSM.
hehe, thanks mate
ip pim ssm default - the saviour - and you.
Beer's are on me!
