NTP and MPLS
efairbanks
I am unable to synchronize my router's clock with a NTP server located in a VRF attached to the router. I specified the MPLS interface in a "ntp source" statement but the debugging output still reports that there is no route to the server. Is this possible to do? Thanks in advance.
Harold Ritter
Level 12
Level 12
You need to configure VRF aware NTP for it to work.
ntp server vrf
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
hritter,
Yeah...I found that right after my post. Don't know how I missed it. Thank you for your prompt response.
-Erik
What if the client router was under a VRF while the NTP is running on the PE in the GRT.
Would the NTP client syncronize in this case..?
