OSPF in VRF with same area ID
Sam Preston
Hello all,
On an MPLS/VPN PE router, I have configured OSPF as the PE/CE routing protocol.
I configured several OSPF processes (one for each VRF).
But if I have several customers who are using the same OSPF area ID on the CE side, may I configure the same area ID for several OSPF processes on the PE side ? Of course, all of those areas are independent and I don't want to see customer1's routes into the OSPF of customer2 !
In the following example, I have 2 customers. Each customer has got 2 sites and has an OSPF backbone area which is spread accross his 2 sites. For each customer, I want to interconnect his 2 sites and extend OSPF backbone area across MPLS.
The OSPF backbone area of customer1 is different from the one of customer2, even if the ID is the same...
Here is a sample of the PE's configuration :
interface G0/1
ip vrf forwarding customer1
ip address 10.1.1.1 255.255.255.0
interface G0/2
ip vrf forwarding customer2
ip address 10.1.2.1 255.255.255.0
router ospf 1 vrf customer1
network 10.1.1.0 0.0.0.255 area 0
router ospf 2 vrf customer2
network 10.1.2.0 0.0.0.255 area 0
Won't I experience problems if I use the same area ID there ?
Thanks for your help !
Mahesh Gohil
Level 7
Level 7
Hello Sam,
You won't face any problem because you have configured cust1 and cust2 under vrf instance within ospf.There will not be any
mixing of routes between cust1 and cust2.
In addition to that also configure domain-id (a /32 unique ip address) under ospf process for each customer. The reason if you configure ospf process
id 1 for cust1 at A-End and if you configure process id 2 for same customer on B-end the routes propogated from A-end will be seen as
inter-area at B-end
ospf domain-id 1.1.1.1 >>> keep this same for this vrf at every site
Hope this is helpful
Mahesh
Mahesh Gohil
Level 7
Level 7
Hello Sam,
inter-area at B-end
Mahesh
Mahesh you said this :
"[...] In addition to that also configure domain-id (a /32 unique ip address) under ospf process for each customer. The reason if you configure ospf process id 1 for cust1 at A-End and if you configure process id 2 for same customer on B-end the routes propogated from A-end will be seen as inter-area at B-end [...]"
I guess you mean :
  • If OSPF domain-id is not the same on PE at both ends, the routes will be exported within type-5 external LSA at B-end
  • If OSPF domain-id matches on PE at both ends, the routes will be exported within type-3 inter-area LSA at B-end.
Thanks.
Hi Sam
For more detail You can refer the document that i had shared . below is the link .
Here you will get clear picture of OSPF with Domain ID & Process ID.
OSPF with unique process = O IA (OSPF Route)
OSPF with different process = O E2 (OSPF Route)
OSPF with unique Process ID but different domain ID = O E2 (OSPF Route)
OSPF with different process ID but unique domain ID = O IA (OSPF Route)
https://learningnetwork.cisco.com/docs/DOC-8648
Chetan Kumar
http://chetanress.blogspot.com
shivlu jain
Level 5
Level 5
Yes you are right you can use; for every customer you can use the same area; this is the main advantage of using MPLS. For domain id you can check the post which tells about to use the domain-id for receiving routes from same customer. By default domain-id is changed for every vrf per PE and you receive one CPE routes to another CPE routes of same vpn as external routes. Please check my post for domain-id:-
http://www.mplsvpn.info/2008/11/why-ospf-vpnv4-routes-look-as-external_07.html
regards
Shivlu Jain
