ospfv3 as PE-CE protocol on XR
sachin30720041
Can we configure ospfv3 as a PE-CE protocol on XR ?
If yes then how to configure vrf aware ospfv3 for the IPV6 address-family?
I am able to configure for ipv4 address family.
router ospfv3 1
router-id 12.12.12.12
vrf vrf1
area 0
int gi0/0/0/0
Sachin
Harold Ritter
Hi @sachin30720041 ,
Yes, you can certainly use ospfv3 as a PE-CE protocol on XR.
ospfv3 on XR only supports ipv6 for now. So this configuration should be sufficient. If you need to provide IPv4 connectivity as well to the CE, you will need to configure ospf version 2 as well.
Harold Ritter
