Ping to PE interface
dangal.43
I configured the MPLSVPN in my test topology which is chain of 6 router 1 and 6 routers are CE routers and all other are for provier network in which 2 and 5 is PE1 and PE2 router, as PE-CE communication i am using RIP, In both the CE router i have configured 3 loop back interface as internal network.
Here i can see the loopback of each other CEs in their routing tables but i cannot able to ping those loopbacks why?
other strang thing is i can not ping the PE routers interface which are connected with the CE routers so i want to know why i cannot ping the PE routers interface facing to CE routers?
How can i make all those loopback reachable to each other?
15 Replies 15
Ken, yes you can run MPLS on a 2600.
Here is a previous thread which discusses the same and the support available for it in 2600.
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Service%20Providers&topic=MPLS&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddc801e
This should be helpful.
HTH-Cheers,
Swaroop
