Please, i need your help to fix my Cisco 3640 Booting Problems ??
I  am stuck and I need your help to fix my CISCO 3460 router for my home  lab, the router load the ios and hang after loading the interfaces.
Please see below the Router IOS display:
Alain
Cisco IOS Software, 3600 Software (C3640-JK9O3S-M), Version 12.3(14)T7, RELEASE
SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 22-Mar-06 21:46 by pwade
Image text-base: 0x60008FD4, data-base: 0x62A2A000
Port Statistics for unclassified packets is not turned on.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com  .
Cisco 3640 (R4700) processor (revision 0x00) with 122880K/8192K bytes of memory.
Processor board ID 28014581
R4700 CPU at 100MHz, Implementation 33, Rev 1.0
3 FastEthernet interfaces
1 Token Ring interface
4 Serial interfaces
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
*Mar  1 00:00:10.711: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0
, changed state to upsslinit fn
*Mar  1 00:00:29.367: %LINK-3-UPDOWN: Interface Serial0/0, changed state to down
*Mar  1 00:00:29.371: %LINK-3-UPDOWN: Interface Serial0/1, changed state to down
*Mar  1 00:00:29.371: %LINK-3-UPDOWN: Interface Serial0/2, changed state to down
*Mar  1 00:00:29.371: %LINK-3-UPDOWN: Interface Serial0/3, changed state to down
*Mar  1 00:00:29.371: %LINK-3-UPDOWN: Interface FastEthernet1/0, changed state t
o up
*Mar  1 00:00:29.371: %LINK-3-UPDOWN: Interface FastEthernet1/1, changed state t
o up
*Mar  1 00:00:29.375: %LINK-3-UPDOWN: Interface FastEthernet3/0, changed state t
o up
o up
state to up
*Mar  1 00:00:31.031: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 08:40:00.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0,
* changed state to down*
*Mar  1 08:40:00.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1,
*Mar  1 08:40:00.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2,
*Mar  1 08:40:00.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/3,
*Mar  1 08:40:00.419: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et1/0, changed state to down
et1/1, changed state to down
et3/0, changed state to down
*Mar  1 08:40:00.419: %LINK-5-CHANGED: Interface Serial0/0, changed state to adm
inistratively down
*Mar  1 08:40:00.419: %LINK-5-CHANGED: Interface Serial0/1, changed state to adm
inistratively down
*Mar  1 08:40:00.419: %LINK-5-CHANGED: Interface Serial0/2, changed state to adm
inistratively down
*Mar  1 08:40:01.707: %LINEPROTO-5-UPDOWN: Line protocol on Interface TokenRing3
11 Replies 11
rizwanr74
Level 7
Level 7
Upload a newer IOS image, via ROMMON, it will boot.
it is a IOS bug.
thanks
Thank you for your quick reply. Actually I have 2 CISCO 3640 with the same issue, I did upload new IOS images in ROMMON mode but the same problem remain.
Thanks.
Remove all the network modules and reboot again.
I already try that option by removing all Network modules and rebooting, but it's still stuck!!!!!!
Did you try a new IOS version?
No I did not. Which one do you suggest me to use ?
You choose base on your the amount of DRAM and flash requirement of your routers.
I will try with the new IOS images and will let you know.
Hi leolaohoo,  I ordered new RAM and flash ( 64/32), installed new ios image, still unable to get inline, WITH A NEW ERROR :
ip kerberos source-interface any
% Invalid input detected at '^' marker.
. please see below the ios image.
Thanks for your help.
System Bootstrap, Version 11.1(17)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
Copyright (c) 1998 by cisco Systems, Inc.
C3600 processor with 65536 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
program load complete, entry point: 0x80008000, size: 0xbcee64
Self decompressing the image : #################################################
[OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
000054          0X00030000 4T Mueslix Serial
0000D8          0X00178610 Dual Fast Ethernet Combo Port Module, 2 WAN
0000D9          0X00143210 Fast Ethernet Combo Port Module, 1 Token Ring, 2 WAN
                0X0010A6F8 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X00606F18
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 7Mb.
Using 10 percent iomem. [7Mb/64Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) 3600 Software (C3640-JS-M), Version 12.1(5)T,  RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Sat 11-Nov-00 07:24 by ccai
Image text-base: 0x60008950, data-base: 0x61476000
cisco 3640 (R4700) processor (revision 0x00) with 58368K/7168K bytes of memory.
Processor board ID 07870836
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
3 FastEthernet/IEEE 802.3 interface(s)
1 Token Ring/IEEE 802.5 interface(s)
4 Serial network interface(s)
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
How long did this message stay up?  I mean how long did you wait before the "Press any key to continue" comes up?
FINALLY THIS IS THE SOLUTION!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I received it today, I started fixing  all my routers
Thanks any way.
Enter  ctrl + break to enter Rommon. Then type confreg 0x2142 and boot. When it  boots the IOS he needs to erase the config with Write erase. That error  shouldn't show anymore when he boots.  Change the  config-register back to 0x2102 though
