Pseudowire does not work
HW Cat6509 SUP720-3BXL
SW 12.2(33)SXH5
Pseudowire configured between two cat6509
does not work
lfi-gw#sh mpls l2transport vc det
Local interface: Vl499 up, line protocol up, Eth VLAN 499 up
MPLS VC type is Eth VLAN, interworking type is IP
Destination address: 134.95.127.110, VC ID: 100, VC status: down
Output interface: none, imposed label stack {545}
Preferred path: not configured
Default path: active
Next hop: Invalid ADDR
Create time: 00:17:44, last status change time: 00:17:12
Signaling protocol: LDP, peer 134.95.127.110:0 up
MPLS VC labels: local 522, remote 545
Group ID: local 0, remote 0
MTU: local 1500, remote 1500
Remote interface description:
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
packet drops: receive 0, send 0
Peter Paluch
Manfred,
It would be very helpful if you posted an excerpt of your configuration that shows your entire pseudowire configuration.
From what you have posted:
Can you elaborate on this?
Best regards,
Peter
Saw the same problem a couple of years ago. Problem was that pseudowire between interface Vlan on 7600(SUP720-3BXL, 67xx linecards) was not supported.
Believe this configuration needed OSM or ES linecards
Jon
