Pseudowire over TE MPLS
francisco_1
Level 7
Level 7
Has anyone used Pseudowire over Traffic Enginnering MPLS?
What i would like to do is setup the MPLS TE using OSPF, built layer 3 tunnels between sites and then use Pseudowire to extend vlans over the TE MPLS tunnels and isolate the vlans using VRF-Lite.
Advice pls..
Francisco
Laurent Aubert
Hi Francisco,
You can map a PW to a MPLS-TE tunnel via the PW-class:
pseudowire-class TE
encapsulation mpls
preferred-path interface Tunnel0
interface Ethernet0/0
xconnect 1.1.1.1 10 pw-class TE
Laurent.
thanks Laurent.
I will give it a go...
Francisco
