" l2vpn vfi context" not work AT ME3600 (me360x-universalk9-mz.153-2.S.bin)
Roberto Falconi
Somebody knows, Why dont work this vfi, this example is working over ME3600 (PE03) and ASR901 (PE01)
configure router PE03 (10.9.0.175)
interface GigabitEthernet0/12
service instance 2561 ethernet
  encapsulation dot1q 2561
  rewrite ingress tag pop 1 symmetric
l2vpn vfi context EXAMPLE
vpn id 2561
member 10.9.0.110 encapsulation mpls
member 10.9.0.10 encapsulation mpls
member 10.9.0.80 encapsulation mpls
bridge-domain 2561
member GigabitEthernet0/12 service-instance 2561
member vfi EXAMPLE
configure router PE01 (10.9.0.80)
  xconnect 10.9.0.175 2561 encapsulation mpls
TSHOOT:
PE01#sh mpls l2transport vc 2561 det
Local interface: Gi0/1 up, line protocol up, Eth VLAN 2561 down
  Destination address: 10.9.0.175, VC ID: 2561, VC status: down
    Last error: Local access circuit is not ready for label advertise
    Output interface: none, imposed label stack {}
    Preferred path: not configured
    Default path: no route
    No adjacency
  Create time: 00:20:44, last status change time: 8w4d
    Last label FSM state change time: 00:20:44
  Signaling protocol: LDP, peer 10.9.0.175:0 up
    Targeted Hello: 10.9.0.80(LDP Id) -> 10.9.0.175, LDP is DOWN, no binding
    Graceful restart: not configured and not enabled
    Non stop routing: not configured and not enabled
    Status TLV support (local/remote)   : enabled/None (no remote binding)
      LDP route watch                   : enabled
      Label/status state machine        : local ready, LruRnd
      Last local dataplane   status rcvd: No fault
      Last BFD dataplane     status rcvd: Not sent
      Last BFD peer monitor  status rcvd: No fault
      Last local AC  circuit status rcvd: No fault
      Last local AC  circuit status sent: Not sent
      Last local PW i/f circ status rcvd: No fault
      Last local LDP TLV     status sent: No fault
      Last remote LDP TLV    status rcvd: None (no remote binding)
      Last remote LDP ADJ    status rcvd: None (no remote binding)
    MPLS VC labels: local 172, remote unassigned
    Group ID: local 0, remote unknown
    MTU: local 1500, remote unknown
    Remote interface description:
  Sequencing: receive disabled, send disabled
  Control Word: On (configured: autosense)
  Dataplane:
    SSM segment/switch IDs: 0/0 (used), PWID: 2
  VC statistics:
    transit packet totals: receive 0, send 0
    transit byte totals:   receive 0, send 0
PE03#sh mpls l2transport vc 2561
Local intf     Local circuit              Dest address    VC ID      Status
VFI EXAMPLE  vfi                        10.9.0.10     2561       DOWN
VFI EXAMPLE  vfi                        10.9.0.80     2561       DOWN
VFI EXAMPLE  vfi                        10.9.0.110    2561       DOWN
PE03#sh mpls l2transport vc 2561 det
Local interface: VFI EXAMPLE vfi down
  Interworking type is Ethernet
  Destination address: 10.9.0.10, VC ID: 2561, VC status: down
    No adjacency
  Create time: 00:35:05, last status change time: 11w0d
    Last label FSM state change time: 00:35:05
  Signaling protocol: LDP, peer unknown
    Targeted Hello: 10.9.0.175(LDP Id) -> 10.9.0.10, LDP is DOWN, no binding
      Label/status state machine        : provisioned, LndRnd
      Last local AC  circuit status rcvd: DOWN(hard-down, not-ready)
      Last local LDP TLV     status sent: No status
    MPLS VC labels: local unassigned, remote unassigned
    Group ID: local unknown, remote unknown
    MTU: local unknown, remote unknown
  Control Word: Off (configured: autosense)
  Dataplane:
    SSM segment/switch IDs: 0/0 (used), PWID: 24
  VC statistics:
    transit packet drops:  receive 0, seq error 0, send 0
  Destination address: 10.9.0.80, VC ID: 2561, VC status: down
    No adjacency
  Create time: 00:35:06, last status change time: 11w0d
    Last label FSM state change time: 00:30:52
  Signaling protocol: LDP, peer 10.9.0.80:0 up
    Targeted Hello: 10.9.0.175(LDP Id) -> 10.9.0.80, LDP is UP
    Status TLV support (local/remote)   : enabled/supported
      Label/status state machine        : remote ready, LndRru
      Last local AC  circuit status sent: No fault
      Last remote LDP TLV    status rcvd: No fault
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local unassigned, remote 172
    Group ID: local unknown, remote 0
    MTU: local unknown, remote 1500
    Remote interface description: *** SERVICIOS VRFs - SWL3 Gi0/47 ***
  Dataplane:
    SSM segment/switch IDs: 0/0 (used), PWID: 25
  VC statistics:
  Destination address: 10.9.0.110, VC ID: 2561, VC status: down
    No adjacency
  Create time: 00:35:07, last status change time: 11w0d
    Last label FSM state change time: 00:35:07
  Signaling protocol: LDP, peer 10.9.0.110:0 up
    Targeted Hello: 10.9.0.175(LDP Id) -> 10.9.0.110, LDP is DOWN, no binding
      Label/status state machine        : ldp ready, LndRnd
  Dataplane:
    SSM segment/switch IDs: 0/0 (used), PWID: 23
  VC statistics:
kammodo21
Have you tried, including the BD under the service-instance?
   bridge-domain 2561 <<<<
if you configure de BD into service instance you can't configure the BD with vfi members
this is the error message:
%The service instance is already a member of bridge-domain 2561
