Route leaking from VRF to Global on same router with VLAN interface
lap
Level 2
Level 2
Hi all,
I would like to do some route leaking from VRF to Global and Global to VRF on the same router. Here is an output of the config:
interface FastEthernet4
description ***Connection to WAN***
ip vrf forwarding FVRF
ip address 10.0.0.6 255.255.255.0
interface Vlan100
description ***LAN***
ip address 192.168.227.1 255.255.255.0
So what I want is to import 192.168.227.0 /24 into FVRF and import 10.0.0.0 /24 into the global routing table.
I though I could do that config but it is not possible:
(config)#ip route vrf FVRF 192.168.227.0 255.255.255.0 vlan 100
% For VPN or topology routes, must specify a next hop IP address if not a point-to-point interface
OR
DK-SLVPN(config)#ip route vrf FVRF 192.168.227.0 255.255.255.0 vlan 100 192.168.227.1 global
%Invalid next hop address (it's this router)
Any ideas are really welcome.
Best regards,
Laurent
17 Replies 17
Ivan Krimmel
Level 7
Level 7
you would end up with MP-BGP
Hi ikrimmel,
Thanks for your message.
So you mean that I have to use MP-BGP. I cannot to otherwise with static routes?
Could you give an example about what you are thinking related to my setup please?
Laurent
Try removing the space from the interface name (vlan100 and not vlan 100).
Hi Andre,
It is the same messages I get when removing the space.
Laurent
I have tried the following solution:
Add 10.0.0.0 /24 From VRFto Global:
ip route 10.0.0.0 255.255.255.0 FastEthernet4
Add 192.168.227.0 /24 from Global to VRF:
router bgp 64512
bgp log-neighbor-changes
address-family ipv4
  no synchronization
  redistribute connected
  no auto-summary
exit-address-family
ip prefix-list Global-VRF seq 5 permit 192.168.227.0/24
route-map Global permit 10
match ip address prefix-list Global-VRF
ip vrf FVRF
rd 1:1
import ipv4 unicast map Global
So now the VRF table looks like that:
#      sh ip route vrf FVRF
C        10.0.0.0/24 is directly connected, FastEthernet4
S        10.0.0.1/32 [254/0] via 10.0.0.1, FastEthernet4
L        10.0.0.6/32 is directly connected, FastEthernet4
B     192.168.227.0/24 is directly connected, 00:15:12, Vlan100
The Global table looks like this:
#sh ip route
Gateway of last resort is 10.1.0.107 to network 0.0.0.0
D*    0.0.0.0/0 [90/1709056] via 10.1.0.107, 3d02h, Tunnel1
      10.0.0.0/8 is variably subnetted, 8 subnets, 2 masks
S        10.0.0.0/24 is directly connected, FastEthernet4
C        10.1.0.0/24 is directly connected, Tunnel1
L        10.1.0.227/32 is directly connected, Tunnel1
C        10.2.0.0/24 is directly connected, Tunnel2
L        10.2.0.227/32 is directly connected, Tunnel2
C        10.10.10.227/32 is directly connected, Loopback100
      192.168.227.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.227.0/24 is directly connected, Vlan100
L        192.168.227.1/32 is directly connected, Vlan100
But When I try to ping it still doesn´t work:
#ping vrf FVRF 192.168.227.1 source fastEthernet 4
Sending 5, 100-byte ICMP Echos to 192.168.227.1, timeout is 2 seconds:
Packet sent with a source address of 10.0.0.6
Success rate is 0 percent (0/5)
#ping 10.0.0.1 source vlan 100
Sending 5, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.227.1
Any ideas?
Laurent
Laurent,
MP-BGP to be used with inter-vrf setups, in your case indeed statics should work:
http://www.cisco.com/en/US/tech/tk436/tk832/technologies_configuration_example09186a0080231a3e.shtml#global
however, pointing the static to the router's address indeed could lead to those messages. What if you'll try to specify a different next-hop on this subnet?
router bgp 64512
address-family ipv4
  no synchronization
  no auto-summary
exit-address-family
ip vrf FVRF
  rd 1:1
#sh ip route
Any ideas?
Laurent
Anu ideas?
Did you try vrf select ?. it will allow you to have each subnet in both the GRT and in a VRF. Please see the following post for an example:
https://supportforums.cisco.com/message/972565#972565
Also on CCO: http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_vpn_vrf_select_rt_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Laurent.
Hi Laurent,
Thanks I have tried and I have the following RIB now:
Global:
#sh ip route
D*    0.0.0.0/0 [90/1709056] via 10.1.0.107, 00:17:20, Tunnel1
C        10.90.227.0/24 is directly connected, Vlan90
L        10.90.227.1/32 is directly connected, Vlan90
      172.16.0.0/32 is subnetted, 1 subnets
C        172.16.10.10 is directly connected, Loopback0
VRF:
#sh ip route vrf FVRF
Gateway of last resort is 10.0.0.1 to network 0.0.0.0
S*    0.0.0.0/0 [254/0] via 10.0.0.1
      10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
So from VRF I can ping 192.168.227.1.(Vlan 100 interface in Global) and from global I can ping 10.0.0.6 (Fa4 IP in VRF).
But I cannot ping for example the other IP in 10.0.0.0 /24 subnet, for example 10.0.0.1 som er DG.
I can ping 10.0.0.1 from the VRF directly.
Any clues?
Laurent
Hi Laurent,
Here is what I tried on a PE running 12.2(33)SRE and it's almost working:
R1--------GRT Eth0/0 PE ---VRF Eth1/0-----R2
Rx default gateway is PE
PE config:
interface Ethernet0/0
description Vers R1
ip address 192.168.2.14 255.255.255.252
ip vrf select source
ip vrf receive MVPN
interface Ethernet1/0
description Vers R2
ip vrf forwarding MVPN
ip address 172.16.4.254 255.255.255.0
ip route 172.16.4.0 255.255.255.0 Ethernet1/0
It looks the same setup as yours but have different results:
- R1 can ping R2
- R1 can ping PE address in VRF (172.16.4.254)
- R2 can't ping PE address in GRT (192.168.2.14). PE is not processing the packet for unknown reason. If PE pings R2 using eth0/0 as source address, I see it receiving the echo-reply without processing it...
Also I found such design is not fully supported on all platform (local route leaking between VRF and GRT) so you may check with your local cisco account team before investigating further this issue. It will prevent you from losing too much time to come to the conclusion you need to review your design.
Laurent.
Hi Laurent,
Sorry for the late reply. I haven't had the possibility to test it with the customer as he decided not to go ahead with the solution.
Best regards,
Laurent
Not this is much help but I've just attempted to implement this myself and unfortuantely drew the ultimate conclusion it wasn't possible.
As such I've chosen to migrate all subnets present in the GRT into a seperate VRF which the allows me to Inter-VRF routing using MP-BGP as previously discussed in this thread.
Although I appreciate that might not be possible depending on your environment, for me it was only 40-50 directly connected subnets (Vlan SVI's).
Once finished the GRT will be empty on my switches with only VRF's present.
kelly.a.murphy
I just had a similar question come up in a what-if scenario that I was labbing out.  We solved this by creating mutual redistribution, using route-maps to control prefixes, between the VRF and Global table.  This requires a locally significant instance of MP-BGP.  It does not require VRF select configurations or static routes.  The removal of static routes can save you from black-hole routing.  Better late, than never.
ip vrf FVRF
 rd 1:1
 import ipv4 unicast map IMPORT-GLOBAL-TO-VRF
 export ipv4 unicast map EXPORT-VRF-TO-GLOBAL
router bgp 64512
 address-family ipv4
 exit-address-family
 address-family ipv4 vrf FVRF
 exit-address-family
ip prefix-list EXPORT-VRF-TO-GLOBAL seq 10 permit 10.0.0.0/24
ip prefix-list IMPORT-GLOBAL-TO-VRF seq 10 permit 192.168.227.0/24
route-map IMPORT-GLOBAL-TO-VRF permit 10
 match ip address prefix-list IMPORT-GLOBAL-TO-VRF
route-map EXPORT-VRF-TO-GLOBAL permit 10
 match ip address prefix-list EXPORT-VRF-TO-GLOBAL
