Route not importet into vrf
m-ott
Following situation:
PE----CE-----Router
6500 3550 2610 -> PE-CE running OSPF
The PE Router distributes all routes into the OSPF vrf process. The problem on the 2610 i have all routes that come from the 6500 in the OSPF table, but the 3550 hasn't got anything in its vrf routing table, also the routes are in the ospf database as summary routes int the right ospf process. I don't know why the 3550 doesn't implement the routes int the routing table, but the 2610 does.
There are no other routes int the 3550 that could influence the import into the routing table. 3550 is runnung the extended-match template for extended routing.
IOS 3550 = 12.1.22EA3
Has anybody made the same experiance?
cheers
patrick
6 Replies 6
Harold Ritter
Can you include a "show ip ospf da summ x.x.x.x" for any of the network summaries on the 3550.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
hi
Do you think about the routing bit which is not set with the down bit? But the 2610 should have the same database and it importes the route... Anyway
Here's the show ip ospf da sum
kapo#sh ip ospf 10 database summary 10.53.145.113
OSPF Router with ID (172.16.10.141) (Process ID 10)
Summary Net Link States (Area 2)
LS age: 1877
Options: (No TOS-capability, DC, Downward)
LS Type: Summary Links(Network)
Link State ID: 10.53.145.113 (summary Network Number)
Advertising Router: 172.16.10.129
LS Seq Number: 8000001C
Checksum: 0x4DC7
Length: 28
Network Mask: /32
TOS: 0 Metric: 2
Thanks for your help
Can you also post the ospf configuration for the 3550.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Sorry for my delay, but i still need your help :)
What i figured out is that the routing bit on the 3550 is not set for the ospf database entry but on the 2610 it is set:
2610#sh ip ospf database sum 193.222.30.1
OSPF Router with ID (193.222.35.1) (Process ID 10)
Summary Net Link States (Area 0)
Routing Bit Set on this LSA
LS age: 681
Link State ID: 193.222.30.1 (summary Network Number)
Advertising Router: 172.16.10.131
LS Seq Number: 80000002
Checksum: 0x7D33
Length: 28
Network Mask: /32
TOS: 0 Metric: 1
3550#sh ip ospf database sum 193.222.30.1
OSPF Router with ID (172.16.10.135) (Process ID 10)
LS age: 695
Checksum: 0x7D33
Length: 28
Network Mask: /32
TOS: 0 Metric: 1
According to my documentation the route is not inserted into the routing table if the routing bit is not set even it would be the best route according to SPF algorithm.
Is it because 3550 has its vrf tables and the 2610 has the global routing table?
The config on the 3550 is the following:
hostname 3550
ip routing
ip vrf 10_KAP
rd 10:10
route-target export 10:10
route-target import 10:10
interface Loopback10
ip vrf forwarding 10_KAP
ip address 172.16.10.135 255.255.255.255
interface Loopback100
ip address 10.53.145.135 255.255.255.255
interface GigabitEthernet0/1
description to d35-1
switchport trunk allowed vlan 12,101
switchport mode trunk
interface GigabitEthernet0/2
description to m11-1
switchport trunk allowed vlan 13,100
interface Vlan11
ip address 172.16.11.97 255.255.255.248
interface Vlan12
ip address 172.16.11.10 255.255.255.248
interface Vlan13
ip address 172.16.11.2 255.255.255.248
interface Vlan100
ip address 10.53.144.26 255.255.255.252
interface Vlan101
ip address 10.53.144.30 255.255.255.252
router ospf 100
router-id 10.53.145.135
log-adjacency-changes
network 10.53.144.0 0.0.1.255 area 0
router ospf 10 vrf 10_KAP
router-id 172.16.10.135
network 172.16.10.135 0.0.0.0 area 0
network 172.16.11.0 0.0.0.7 area 0
network 172.16.11.8 0.0.0.7 area 0
network 172.16.11.96 0.0.0.7 area 0
ip classless
ip http server
The sh ip ospf database:
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
172.16.10.131 172.16.10.131 1463 0x8000000C 0x001D41 3
172.16.10.135 172.16.10.135 1492 0x80000006 0x00FC3D 3
172.16.11.83 172.16.11.83 1909 0x80000006 0x00CD0E 2
193.222.35.1 193.222.35.1 1411 0x8000000A 0x00E684 2
172.16.11.2 172.16.10.135 1492 0x80000002 0x001976
172.16.11.83 172.16.11.83 406 0x80000005 0x00178A
172.16.11.98 193.222.35.1 1411 0x80000002 0x007BC2
172.16.10.129 172.16.10.131 1706 0x80000002 0x00190F
172.16.11.88 172.16.10.131 1706 0x80000002 0x007FD7
193.222.30.1 172.16.10.131 1708 0x80000002 0x007D33
cheers patrick
Hi again...
I think it could be the problem with the routing bit, because i configured BGP for the PE - CE (6500 - 3550) and it worked fine...
Is there a workaround for this problem with ospf.
Cheers
patrick
That is what I thought. I just wanted to confirm that you were using VRF lite (multi-vrf) on the CE. You need to use the "capability vrf-lite" command under the OSPF process when vrf-lite is configured. This tells the ospf process to ignore the "downward" bit and to install the summary route in the routing table. You don't have the same issue on the 2610 cause you don't use multi-vrf.
Please refer to the following URL for more info on this command:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/iprrp_r/ip2_c1g.htm#wp1036522
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
