TE with MPLA exp bit set
ponparthi
Hello
I have a multilink bundle which will be the path used for my primary tunnel. I need to set mpls exp bit for qos (bandwidth reservation for specific traffic class)
Now iam applying my service policy applied on the multilink interface.
If enable my tunnel with explicit path configured as the ips of Multilink interfaces where should my service policy go either on the tunnel interface or Multilink interface.
Futher when my primary tunnel fails i have another path configured as next path option either explicit or dynamic. Can i have the same qos on the other path also if enable the service policy on the tunnel interface.
REgards
Parthiban
