ATTENTION: We are currently working an issue with posting. Thank you for your patience while we work on a resolution.
Terminatng MPLS
y.heidary
hi
What do I need for terminating a MPLS link that comes from telco site with fibr optic?
thank you
swaroop.potdar
Level 7
Level 7
Since the 878 router doesnt have any optical ports on it, you will have to termiate that link on a local switch (if the switch has optics on it).
If the switch also doesnt the compatible optics/or no optics then your best best to to purchase a good quality media convertor and connect the incoming fiber to the router via copper (this wont disable or degrade any functionality).
HTH-Cheers,
Swaroop
