Unknown Protocol Drops on CE Router WAN Interface
arun.patro
Team,
I saw few past posts on this, but couldn't find an exact match. So, I am posting here again. Appreciate any feedback on this.
Issue: Observed 'unknown protocol drops' on WAN interface connecting to AT&T WAN Circuit. Also, this counter increases at same time as Multicast counter. See below 'sh int gi0/0/0' output. Required counters underlined in below output.
Router#sh int gi0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
Hardware is ISR4451-X-4x1GE, address is 3473.2d4a.d100 (bia 3473.2d4a.d100)
Description: link to PE; Location: RESTON, VA; Circuit ID: IZEC.544720..ATI
MTU 1500 bytes, BW 400000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 34/255, rxload 16/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive not supported
Full Duplex, 1000Mbps, link type is auto, media type is LX
output flow-control is off, input flow-control is off
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 4d08h
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 1
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
5 minute input rate 26038000 bits/sec, 14825 packets/sec
5 minute output rate 53348000 bits/sec, 24418 packets/sec
1623435152 packets input, 358169497147 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 12543 multicast, 0 pause input
2642593378 packets output, 840628799127 bytes, 0 underruns
Output 0 broadcasts (0 IP multicasts)
12543 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Router interface config as below:
Router#sh run int gi0/0/0
Building configuration...
Current configuration : 165 bytes
interface GigabitEthernet0/0/0
description link to PE
bandwidth 400000
no ip address
negotiation auto
end
Router#sh run int Gi0/0/0.3
Current configuration : 445 bytes
interface GigabitEthernet0/0/0.3
description CE to PE -
bandwidth 400000
encapsulation dot1Q 3
ip flow monitor GLSFlowMonitor1 input
ip flow monitor GLSFlowMonitor1 output
ip address 10.64.16.165 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no cdp enable
bfd interval 999 min_rx 999 multiplier 3
no bfd echo
service-policy output MNS_COS_SHAPING_70-15-30-40-10-5
end
Router#
Let me know if any additional details required to check further. Thank you.
balaji.bandi
clear the counters, try no negotiation on the interface and check.
BB
Giuseppe Larosa
Hello @arun.patro ,
I have seen this in the past with the other side router sending IS-IS hello packets that are non IP based but they are multicast.
So this can be a possible explanation the PE side is running an IS-IS process on its interface.
This has no real impact on your communication given the high difference between rx input packets and the unknown packet drops
Hope to help
Giuseppe
Thanks for the input. Here I check the PE side interface config. Is there anything else I should look at?
PE#sh run int TenGigE0/5/0/0.121
interface TenGigE0/5/0/0.121
description
bandwidth 400000
service-policy input V6_Ex_400M_70:15M:30M:40M:10:5M_in_sub shared-policy-instance 1
service-policy output V6_Ex_400M_70:15N:30W:40W:10:5W_out_sub shared-policy-instance 1
vrf 13979:452212
ipv4 mtu 1500
ipv4 address 10.64.16.166 255.255.255.252
dot1q vlan 70 3
description
mtu 9122
carrier-delay up 2000 down 2000
load-interval 30
