virtual console connectivity...
mukeshpal
Level 2
Level 2
what will be the basic configuration is required in the router to make router as it is directly connected through console once will telnet the router with some port number.
can anyboy suggest the config???
Regards...Mukesh
jayjorda
Are you trying to setup a router to be a terminal/comm server? If so, here is a URL that explains how to set it up.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
In order to do so you're using Reverse Telnet with the port number of the Async port you want to connect to. It's explained pretty well in the URL.
Jay
Hi Jay,
It really help ful, thanks.
Regards...Mukesh
