VPLS CE-CE IGP not working
sp2720401
I have the following setup
CE-PE-PE-CE
I have setup a l2vpn with a vfi and bridge domain. Unicast is working fine, but I cannot get link local multicast. The CEs need to have OSPF adjacency without neighbor statements to make the PE-PE connection look as transparent as possible to the CE. I was under the impression that multicast, broadcast, and unknown unicast would be flooded but it does not seem to be working this way.
It is probably something simple but I cannot get it working.
Chuan Liu
Have you got this working?
I am having the same issue with VPLS built on ASR1K. Multicast is not getting through to the other side.
Regards.
Can you paste your Bridge-domain / relevant config?
One of the ASR1001 routers has the following configs. The other 2 ASR1001 have similar configs.
OSPF between CE's are not forming adjacency unless I manaually set the ospf network type to 'nonbroadcast' and use 'neighbor' commands. RIP and eigrp are not  working either. Multicast traffic simply does not go through the VPLS.
I tried using vfi auto discovery but failed even for unicast traffic.
Regards.
Thanks.
bridge-domain 101
l2 vfi TEST manual
vpn id 11
bridge-domain 101
neighbor 172.16.33.15 102 encapsulation mpls
neighbor 172.16.33.2 102 encapsulation mpls
interface GigabitEthernet0/0/0
mtu 9216
no ip address
load-interval 30
negotiation auto
cdp enable
service instance 101 ethernet
  encapsulation dot1q 101
  rewrite ingress tag pop 1 symmetric
  bridge-domain 101
