VPLS in VIRL using CSR1000v
mmoraba
Hi All
Can anyone provide me an example of extending vlan over VPLS using ios-xe. i am more interested about the CE config as the PE config is well demonstrated on the below link:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/mp_l2_vpns/configuration/xe-3s/mp-l2-vpns-xe-3s-book/mp-vpls.html#GUID-BAD7A7D4-0E29-4F48-8462-AF0A7FB9E4F1
However i want to see what the CE config looks like particularly with VLANs. Thanks!
2 Accepted Solutions
Victor Acevedo
Hello Mmoraba,
The CE's will usually have subinterfaces if they are routers or they will have SVI's configured and have a trunk interface towards your PE devices. The PE devices will then be configured with EVC to accept and put the Vlans in their respective bridge-domain which will then be sent across the pseudowire.
You can take a look at the following config snipplet for a simple VPLS setup with XE devices as the PE's and carrying Vlan Tags.
Note that this setup may not work using VIRL XE devices.
PE1:
PE1#sh run int g0/0/0      <<<< Attachment circuit towards CE1
interface GigabitEthernet0/0/0
no ip address
negotiation auto
service instance 192 ethernet
encapsulation dot1q 192
bridge-domain 192
PE1#sh run | sec vfi
l2 vfi VPLS1 manual
vpn id 192
bridge-domain 192
neighbor 110.2.2.2 encapsulation mpls
PE2:
PE2#sh run int g0/0/0
no ip address
negotiation auto
bridge-domain 192
PE2#sh run | sec vfi
l2 vfi VPLS1 manual
vpn id 192
bridge-domain 192
neighbor 110.1.1.1 encapsulation mpls
CE1:
CE1#sh run int g0/0/0.192
interface GigabitEthernet0/0/0.192
encapsulation dot1Q 192
R11-ISR4k-2#ping 192.168.1.2
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
CE2:
CE2# sh run int g0/0/0.192
ip address 192.168.1.2 255.255.255.0
CE2# ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Hey Mmoraba,
Yes, this is on a CSR1kv running IOS XE. You can use the new syntax as follows for the CE's
no ip address
encapsulation dot1Q
192
bridge-domain 192
CE1#sh run int bdi192
interface BDI192
CE1#ping 192.168.1.1
no ip address
encapsulation dot1Q
192
bridge-domain 192
CE2#sh run int bdi192
interface BDI192
CE2#ping 192.168.1.2
Victor Hugo Acevedo
5 Replies 5
Victor Acevedo
Hello Mmoraba,
PE1:
no ip address
negotiation auto
bridge-domain 192
l2 vfi VPLS1 manual
vpn id 192
bridge-domain 192
PE2:
no ip address
negotiation auto
bridge-domain 192
l2 vfi VPLS1 manual
vpn id 192
bridge-domain 192
CE1:
CE2:
Hi Victor
Is this on ios-xe? particularly on CSR1000v? I see you also using the legacy syntax, does the new syntax produce same results?
Hey Mmoraba,
no ip address
encapsulation dot1Q
192
bridge-domain 192
interface BDI192
no ip address
encapsulation dot1Q
192
bridge-domain 192
interface BDI192
Victor Hugo Acevedo
Hi Victor
Thanks a lot. i really appreciate all the help you provided. Thanks once again. it works just fine now!
Hey Mmoraba,
Not a problem, I am glad this information has helped. If it solved your problem please consider clicking on the "Endorse Answer" to mark this as solved.
Thanks!
Victor Hugo Acevedo
