VRF-Lite QOS on Ethernet Subinterfaces
frank
The router is not allowing me to add QOS service policy under Ethernet subinterfaces in a VRF-life setup on 7206.
Would QOS work for all the VRF if I create multiple classes for each VRF under one main policy-map and apply to main interface?
7 Replies 7
Laurent Aubert
Could you share your configuration ? it should work.
Laurent.
Laurent,
Thanks for the reply.
Can you provide a link for the sample as I can't find any sample from CCO and what I found are all under Ethernet physical interface for VRF based QOS.
We can apply the QOS under subinterfaces for GSR PE router but the CE are 7206s.
We need to make sure it works before we create the temple for our IE.
I was not able to find any useful link on CCO.
Could you post the error message and the service-policy you want to apply per subinterface ?
Laurent.
Here is what I got from the 7206:
Router(config)#int f0/0.1
Router(config-subif)#ser
Router(config-subif)#service-policy ?
input Assign policy-map to the input of an interface
output Assign policy-map to the output of an interface
Router(config-subif)#service-policy output ?
WORD policy-map name
Router(config-subif)#service-policy output PIP-EMDC-BAKU-3400
CBWFQ : Not supported on subinterfaces
It is only expecting input or output not the policy map but is not taking it somehow.
Ok so the link provided by Jon explains your issue and how to resolve it.
Let me know if you have other question regarding this non support of CBWFQ on subinterfaces.
Laurent.
Yes, the link that Jon provided works.
Thanks for the helps.
