VRF lite with OSPF
helenio
I'd like to use VRF lite on Cat. 3750 in a way to have two OSPF idependent process.
For test purpose I created only one VRF (here the VRF config):
ip routing
ip vrf A1
rd 1:1
interface Vlan1
ip vrf forwarding A1
ip address 10.1.9.1 255.255.255.0
vlan 11
exit
interface vlan 11
ip address 10.1.10.2 255.255.255.0
no shut
router ospf 1 vrf A1
log-adjacency-changes
network 10.1.9.0 0.0.0.255 area 1
network 10.1.10.0 0.0.0.255 area 1
VLAN 11 is phisically connected to the Backbone.
The routes of the VRF A1 table is inclomplete only intra-area (area 1) routes are present and no Inter area, i.e. Area 2 routes.
There is some limitation for multiarea OSPF when use VRF lite ?
Harold Ritter
you need to configure the "capability vrf-lite" command under "router ospf 1 vrf A1".
Let me know if I answered your question,
.. perfect it work ! thank's ...
When I use VRF-lite for router virtualisation and Campus segmentation why should I configure Route Distinguisher ?
In this context, the RD is not really required but certain releases of IOS require that RD be defined.
You can basically use anything as long as it doesn't conflict with another VRF on the same box.
Let me know If I answered your question,
Yes, this really solve my doubt about it. Thank's again.
