VRF OSPF
aretsu
We are migrating an ISP network from using EIGRP to OSPF. Some of their networks are running on a VRF, so to make a smooth migration we need to run both protocols on the same VRF, is this possible?
If so, are all the standard OSPF features available in the VRF? we are planning to use authenticacion (MD5) and NSSA (stub areas)
Thanks!
Alex
gmarogi
Level 5
Level 5
Yeah, you can use both the protocols simultaneously under a VRF. Authenticacion (MD5) and NSSA (stub areas) are supported under the VRF.
mstyszynski
ospf with vrfs has some limitations like a lack of passive interfaces what seems to ruin sometimes a routing plan that you already have;
cheers
michal
Passive-interface under OSPF vrf is now available in 12.0(31)S, 12.4(2), 12.2(18)SXE.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
