VRF selction
anasubra_2
Level 5
Level 5
Is VRF selection feature been integrated in 7600 platform based IOS trains..If so, can you please let know .
Anantha Subramanian Natarajan
VRF Selection with PBR is an enhancement over for the the previous source based selection. As you have multiple selection criteria available with the policy map and you can set the VRF with your match criteria.
HTH-Cheers,
Swaroop
swaroop.potdar
Level 11
Level 11
Yes, its been there since 12.2SR.
Here is the link on the configuration details.
http://www.cisco.com/en/US/products/ps6922/products_command_reference_chapter09186a00806c0fe3.html#wp1020866
HTH-Cheers,
Swaroop
oh ,thanks, i hope this feature would select the vrf based on PBR right ?? I was trying understand abt the improved version of the same being implemented as below link
http://www.cisco.com/en/US/products/ps6604/products_white_paper09186a00804fbfac.shtml
Do you think, this feature even integrated on the above IOS mentioned
Anantha Subramanian
HTH-Cheers,
Swaroop
oh is it...thanks ...i think both may helps us if we have the correct IOS on the network
