xconnect not up, please help
xuancuong1188
dear all,
i am configuring l2vpn between PEs using xconnect, but i have some problems. please help me
show xconnect all
Legend:    XC ST=Xconnect State  S1=Segment1 State  S2=Segment2 State
  UP=Up       DN=Down            AD=Admin Down      IA=Inactive
  SB=Standby  HS=Hot Standby     RV=Recovering      NH=No Hardware
XC ST  Segment 1                         S1 Segment 2                         S2
DN pri ac   Gi1/1.3031:3031(Eth VLAN)    UP mpls x.x.x.1:3031          DN
IA sec ac   Gi1/1.3031:3031(Eth VLAN)    UP mpls x.x.x.2:3031          DN
i don't know why the xc down
Local interface: Gi1/1.3031 up, line protocol up, Eth VLAN 3031 up
  Destination address: x.x.x.2, VC ID: 3031, VC status: down
    Output interface: none, imposed label stack {}
    Preferred path: not configured
    Default path: no route
    No adjacency
  Create time: 14:06:24, last status change time: 00:00:32
  Signaling protocol: LDP, peer x.x.x.2 : 0 up
    Targeted Hello: x.x.x.x (LDP Id) -> x.x.x.2, LDP is UP
    Status TLV support (local/remote)   : enabled/not supported
      LDP route watch                   : enabled
      Label/status state machine        : activating, LruRru
      Last local dataplane   status rcvd: No fault
      Last local SSS circuit status rcvd: No fault
      Last local SSS circuit status sent: No fault
      Last local  LDP TLV    status sent: No fault
      Last remote LDP TLV    status rcvd: Not sent
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 3275, remote 392640
    Group ID: local 0, remote 0
    MTU: local 1500, remote 1500
    Remote interface description:
    Remote VLAN id: 3031
    MAC Withdraw: sent:4, received:0
  Sequencing: receive disabled, send disabled
  Control Word: Off (configured: autosense)
  VC statistics:
    transit packet totals: receive 0, send 0
    transit byte totals:   receive 0, send 0
    transit packet drops:  receive 0, seq error 0, send 0
- ldp established with the other PE.
interface GigabitEthernet1/1.3031
encapsulation dot1Q 3031
xconnect x.x.x.2 3031 encapsulation mpls pw-class aaata
  backup peer x.x.x.x 3031 pw-class aaata
i'm appreciate for your help
5 Replies 5
Nagendra Kumar Nainar
Can you check if you have mpls enabled on egress interface to reach PW destination address? (x.x.x.2 from "
xconnect x.x.x.2 3031 encapsulation mpls pw-class aaata")
Checked show ip cef "PW destination" address and see if it have any label (eitehr null label or non-null label), but it should not be Unlabelled.
HTH,
Nagendra
thank for you reply
show ip cef x.x.x.2
x.x.x.2/32
  nexthop a TenGigabitEthernet8/3
  nexthop b TenGigabitEthernet8/1
  nexthop c TenGigabitEthernet8/2
i don't see any label here
i have enabled on that interface
mpls ip
mpls ip
When the PW destination is unlabelled in local router, xconect will not come up.
Check  if you have LDP session up with the nexthop on the egress interface.  Try "show mpls ldp neighbor ".
Check if you mpls ldp enabled on nexthop routers.
-Nagendra
Mohammed Imran Khan
I see that the core interface is TenGigabitEthernet8/x. Can you please confirm what kind of line card is module 8.
Imran
Enable the MPLS IP command in global and interface level.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
