xconnect not working
salchipatatas
Hi , I'm studying for CCNP SP and I use GNS3 for the labs. I'm trying to config a xconnect and the tunnel is up but no connectivity between CEs. I don't know if I'm missing something or GNS3 doesn't work fine
It seems all is working fine :
LDP sessions UP
OSPF OK
MPLS LABELS OK
XCONNECT UP , VC UP
But can't ping from R1 to R2
C1#show mpls ldp neighbor
Peer LDP Ident: 10.0.0.3:0; Local LDP Ident 10.0.0.1:0
TCP connection: 10.0.0.3.38251 - 10.0.0.1.646
State: Oper; Msgs sent/rcvd: 39/39; Downstream
Up time: 00:27:12
LDP discovery sources:
GigabitEthernet3, Src IP addr: 10.0.1.3
Addresses bound to peer LDP Ident:
10.0.1.3 10.0.0.3 10.0.2.3
Peer LDP Ident: 10.0.2.2:0; Local LDP Ident 10.0.0.1:0
TCP connection: 10.0.2.2.46392 - 10.0.0.1.646
State: Oper; Msgs sent/rcvd: 37/38; Downstream
Up time: 00:25:18
Targeted Hello 10.0.0.1 -> 10.0.0.2, active
10.0.2.2 10.0.0.2
C1#
C1#show mpls forwarding-table
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or Tunnel Id Switched interface
16 No Label 10.0.0.3/32 0 Gi3 10.0.1.3
17 16 10.0.0.2/32 0 Gi3 10.0.1.3
18 Pop Label 10.0.2.0/24 0 Gi3 10.0.1.3
19 No Label l2ckt(1) 0 Gi1 point2point
C1#
C1#show xconnect all
Legend: XC ST=Xconnect State S1=Segment1 State S2=Segment2 State
UP=Up DN=Down AD=Admin Down IA=Inactive
SB=Standby HS=Hot Standby RV=Recovering NH=No Hardware
XC ST Segment 1 S1 Segment 2 S2
UP pri ac Gi1:7(Ethernet) UP mpls 10.0.0.2:12 UP
C1#
C1#show mpls l2transport vc
Local intf Local circuit Dest address VC ID Status
Gi1 Ethernet 10.0.0.2 12 UP
C1#
C1#show mpls l2transport vc detai
Local interface: Gi1 up, line protocol up, Ethernet up
Destination address: 10.0.0.2, VC ID: 12, VC status: up
Output interface: Gi3, imposed label stack {16 19}
Preferred path: not configured
Default path: active
Next hop: 10.0.1.3
Create time: 00:25:41, last status change time: 00:25:19
Last label FSM state change time: 00:25:18
Signaling protocol: LDP, peer 10.0.2.2:0 up
Targeted Hello: 10.0.0.1(LDP Id) -> 10.0.0.2, LDP is UP
Graceful restart: not configured and not enabled
Non stop routing: not configured and not enabled
Status TLV support (local/remote) : enabled/supported
LDP route watch : enabled
Label/status state machine : established, LruRru
Last local dataplane status rcvd: No fault
Last BFD dataplane status rcvd: Not sent
Last BFD peer monitor status rcvd: No fault
Last local AC circuit status rcvd: No fault
Last local AC circuit status sent: No fault
Last local PW i/f circ status rcvd: No fault
Last local LDP TLV status sent: No fault
Last remote LDP TLV status rcvd: No fault
Last remote LDP ADJ status rcvd: No fault
MPLS VC labels: local 19, remote 19
Group ID: local n/a, remote 0
MTU: local 1500, remote 1500
Remote interface description:
Sequencing: receive disabled, send disabled
Control Word: On (configured: autosense)
SSO Descriptor: 10.0.0.2/12, local label: 19
Dataplane:
SSM segment/switch IDs: 4097/4096 (used), PWID: 1
VC statistics:
transit packet totals: receive 0, send 195
transit byte totals: receive 0, send 25092
transit packet drops: receive 0, seq error 0, send 0
C2#show mpls ldp neighbor
Peer LDP Ident: 10.0.0.3:0; Local LDP Ident 10.0.2.2:0
TCP connection: 10.0.0.3.646 - 10.0.2.2.30844
Up time: 00:27:35
GigabitEthernet3, Src IP addr: 10.0.2.3
Peer LDP Ident: 10.0.0.1:0; Local LDP Ident 10.0.2.2:0
TCP connection: 10.0.0.1.646 - 10.0.2.2.46392
State: Oper; Msgs sent/rcvd: 38/38; Downstream
Up time: 00:25:36
Targeted Hello 10.0.0.2 -> 10.0.0.1, passive
10.0.1.1 10.0.0.1
C2#
C2#show mpls forwarding-table
16 No Label 10.0.0.3/32 0 Gi3 10.0.2.3
17 Pop Label 10.0.1.0/24 0 Gi3 10.0.2.3
18 17 10.0.0.1/32 0 Gi3 10.0.2.3
C2#
C2#show xconnect all
UP pri ac Gi1:7(Ethernet) UP mpls 10.0.0.1:12 UP
C2#
C2#show mpls l2transport vc
Gi1 Ethernet 10.0.0.1 12 UP
C2#
C2#show mpls l2transport vc detai
Destination address: 10.0.0.1, VC ID: 12, VC status: up
Output interface: Gi3, imposed label stack {17 19}
Next hop: 10.0.2.3
Create time: 00:26:19, last status change time: 00:25:36
Last label FSM state change time: 00:25:36
Signaling protocol: LDP, peer 10.0.0.1:0 up
Targeted Hello: 10.0.2.2(LDP Id) -> 10.0.0.1, LDP is UP
SSO Descriptor: 10.0.0.1/12, local label: 19
Dataplane:
VC statistics:
transit packet totals: receive 0, send 0
transit byte totals: receive 0, send 0
C3#show mpls ldp neighbor
Peer LDP Ident: 10.0.2.2:0; Local LDP Ident 10.0.0.3:0
TCP connection: 10.0.2.2.30844 - 10.0.0.3.646
Up time: 00:26:38
GigabitEthernet2, Src IP addr: 10.0.2.2
10.0.2.2 10.0.0.2
Peer LDP Ident: 10.0.0.1:0; Local LDP Ident 10.0.0.3:0
TCP connection: 10.0.0.1.646 - 10.0.0.3.38251
Up time: 00:26:32
GigabitEthernet1, Src IP addr: 10.0.1.1
10.0.1.1 10.0.0.1
C3#
C3#show mpls forwarding-table
16 No Label 10.0.0.2/32 12996 Gi2 10.0.2.2
17 No Label 10.0.0.1/32 43339 Gi1 10.0.1.1
C3#
C3#show xconnect all
Thanks!!!!
as I remember the LDP ID must be same as Xconnect IP you use otherwise the Xconnect is failed.
Which platform are you using in GNS3? I would be surprised if anything
other than xrv9000v would support l2vpn technology at data plane.
Have you checked your ios version supported features?
Harold Ritter
As Loris mentioned, you need to use XR9000v to run l2vpn in the data plane. You can also use a CSR1000v. XRv will work at the control plane level, but not at the data plane level.
