CloudCenter Suite installer 5.0 always fails on VMware
mschedrin
I have attempted to install CCS 5.0 on VMware vSphere 6.7 several times, but it always fails on Suite configuration:
On another attempts I have also seen alternative error message:
time="2019-04-04T10:26:27Z" level=info msg=". Message: Pod, common-framework-suite-auth-5b89b7b65c-cqxq4, FailedMount, MountVolume.SetUp failed for volume \"suite-auth-tls\" : secrets \"suite-auth-tls\" not found"
I am following the guide: https://docs.cloudcenter.cisco.com/display/INSTALL/VMware+vSphere+Installation
I deploy new Kubernetes cluster on VMware.
Has anyone experienced same issue?
