802.1x and Mab same policy
JonathanC1
Hi folks,
I’ve got a specific use case whereby we need to use peap-mschapv2 and add a condition where by the device has to be in a endpoint identity group by mac.
For example the workflow - User connects to wireless with an ssid that is 802.1x enabled and then authenticated like usual with peap + mschapv2. The authorisation policy then needs to to include the group they are in AD I.e domain users AND also the device needs to be an endpoint identity group with their MAC address. They then get the authorisation result I.e Permit.
Is this possible or am I overthinking
BW
Jon
2 Accepted Solutions
Nancy Saini
You can create an authentication policy with AD as identity source and in the authorization policy put endpoint group as the condition. This should cover your scenario
thomas
Yes. You should have just tried it.  8-)
Nancy Saini
So can’t do both with the condition? E.g if user is in a certain group in ad. Thx
authentication would be one of the conditions to get to the policies IE, user is a user in AD, then use the conditions in the policy rules to verify any group membership etc.
Example for us is for a wireless device to go on internal network, we have ISE keep a record of devices themselves and call to check that the MAC is a domain PC with the WasMachineAuthenticated.
If, you are looking to check both in AD, you can do EAP chaining, but that will just check a user and that it's a domain PC, not check for specific groups.
thomas
