ACS 2.6 / user d exactly after 10 minutes why ? analog or ISDN same result
p.emery
hi
i have a cisco Router 3640 with modem and it is a NAS and every user is autorise from Cisco Secure 2.6 and unfortunatly every 10 minutes exactly ...it didn't depends from ISDN or analogique and i have tried to foud in cisco secure or inside the route which parameters could sbe bad but i cand find which disturb my user
could you help me ?
here is the router config :
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname NAS_3640_1
logging buffered 4096 debugging
logging rate-limit console 10 except errors
aaa new-model
aaa authentication login default group radius
aaa authentication login no_radius local
aaa authentication ppp dial_in group radius
aaa authorization network default group radius
aaa authorization network dial_in group radius
enable secret 5 <removed>
username test1 password 7 <removed>
username admin password 7 <removed>
modem country mica XXXX
ip subnet-zero
no ip finger
virtual-profile virtual-template 1
virtual-profile aaa
isdn switch-type basic-net3
interface Loopback0
description for PPP Users
ip address 172.16.248.1 255.255.255.0
interface FastEthernet0/0
ip address 192.168.254.3 255.255.255.0
duplex auto
speed auto
interface BRI1/0
no ip address
encapsulation ppp
dialer rotary-group 1
isdn incoming-voice modem
no cdp enable
ppp authorization dial_in
interface BRI1/1
no ip address
encapsulation ppp
no cdp enable
interface BRI1/2
no ip address
encapsulation ppp
no cdp enable
interface BRI1/3
no ip address
encapsulation ppp
no cdp enable
interface FastEthernet3/0
ip address 192.168.240.1 255.255.255.252
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered Loopback0
ppp authentication chap dial_in
interface Group-Async1
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer in-band
dialer idle-timeout 7200
async default routing
async dynamic address
async mode dedicated
no peer default ip address
group-range 65 76
interface Dialer1
encapsulation ppp
dialer in-band
dialer-group 1
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.254.1
no ip http server
radius-server host 192.168.240.2 auth-port 1645 acct-port 1646
radius-server retransmit 3
radius-server key 7 <removed>
line con 0
login authentication no_radius
transport input none
line 65 76
autoselect during-login
autoselect ppp
login authentication dialin
modem InOut
modem autoconfigure discovery
transport input all
stopbits 1
flowcontrol hardware
line aux 0
line vty 0 4
exec-timeout 0 0
many thanks for your helps
philippe
p.emery
here i have the log from an ISDN connection :
1d02h: %LINK-3-UPDOWN: Interface BRI1/0:1, changed state to up
1d02h: BR1/0:1 AAA/AUTHOR/FSM: (0): LCP succeeds trivially
1d02h: AAA: parse name=BRI1/0:1 idb type=14 tty=-1
1d02h: AAA: name=BRI1/0:1 flags=0x55 type=2 shelf=0 slot=1 adapter=0 port=0 chan
nel=1
1d02h: AAA: parse name= idb type=-1 tty=-1
1d02h: AAA/MEMORY: create_user (0x6156048C) user='coucou' ruser='' port='BRI1/0:
1' rem_addr='0329533045/9533005' authen_type=CHAP service=PPP priv=1
1d02h: AAA/AUTHEN/START (3354427015): port='BRI1/0:1' list='dial_in' action=LOGI
N service=PPP
1d02h: AAA/AUTHEN/START (3354427015): found list dial_in
1d02h: AAA/AUTHEN/START (3354427015): Method=radius (radius)
1d02h: RADIUS: ustruct sharecount=1
1d02h: RADIUS: Initial Transmit BRI1/0:1 id 30 192.168.240.2:1645, Access-Reques
t, len 98
1d02h: Attribute 4 6 C0A8F001
1d02h: Attribute 5 6 00007531
1d02h: Attribute 61 6 00000000
1d02h: Attribute 1 8 636F7563
1d02h: Attribute 30 9 39353333
1d02h: Attribute 31 12 30333239
1d02h: Attribute 3 19 1B0AA1D5
1d02h: Attribute 6 6 00000002
1d02h: Attribute 7 6 00000001
1d02h: RADIUS: Received from id 30 192.168.240.2:1645, Access-Accept, len 186
1d02h: Attribute 10 6 00000000
1d02h: Attribute 11 8 3130312E
1d02h: Attribute 22 29 3137322E
1d02h: Attribute 26 49 00000009012B6970
1d02h: Attribute 26 50 00000009012C6970
1d02h: Attribute 8 6 AC10F8FE
1d02h: Attribute 9 6 FFFFF800
1d02h: AAA/AUTHEN (3354427015): status = PASS
1d02h: BR1/0:1 AAA/AUTHOR/LCP: Authorize LCP
1d02h: BR1/0:1 AAA/AUTHOR/LCP (1395507533): Port='BRI1/0:1' list='dial_in' servi
ce=NET
1d02h: AAA/AUTHOR/LCP: BR1/0:1 (1395507533) user='coucou'
1d02h: BR1/0:1 AAA/AUTHOR/LCP (1395507533): send AV service=ppp
1d02h: BR1/0:1 AAA/AUTHOR/LCP (1395507533): send AV protocol=lcp
1d02h: BR1/0:1 AAA/AUTHOR/LCP (1395507533): found list "dial_in"
1d02h: BR1/0:1 AAA/AUTHOR/LCP (1395507533): Method=radius (radius)
1d02h: RADIUS: cisco AVPair "ip:dns-servers=172.16.69.17 172.16.121.17" not appl
ied for lcp
1d02h: RADIUS: cisco AVPair "ip:wins-servers=172.16.69.20 172.16.121.21" not app
lied for lcp
1d02h: BR1/0:1 AAA/AUTHOR (1395507533): Post authorization status = PASS_REPL
1d02h: BR1/0:1 AAA/AUTHOR/LCP: Processing AV service=ppp
1d02h: BR1/0:1 AAA/AUTHOR/LCP: Processing AV routing*false
1d02h: BR1/0:1 VP: Create and clone from virtual-template 1
1d02h: Vt1 VTEMPLATE: (Pre)cloning vaccess from recycle queue
1d02h: Vi1 VTEMPLATE: Has a new cloneblk vtemplate, now it has vtemplate
1d02h: Vi1 VTEMPLATE: ************* CLONE VACCESS1 *****************
1d02h: Vi1 VTEMPLATE: Clone from Virtual-Template1
interface Virtual-Access1
default ip address
no ip address
encap ppp
ip unnumbered loopback 0
enc ppp
encapsulation ppp
end
1d02h: Vi1 VP: Create Virtual Profile for BR1/0:1
1d02h: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
1d02h: Vi1 VP: Bind to BR1/0:1
1d02h: Vi1 VP: Bind fastswitching vectors
1d02h: Vi1 VP: Copied LCP state from BR1/0:1
1d02h: Vi1 AAA/AUTHOR/FSM: (0): Can we start IPCP?
1d02h: Vi1 AAA/AUTHOR/FSM (2212599508): Port='BRI1/0:1' list='dial_in' service=N
ET
1d02h: AAA/AUTHOR/FSM: Vi1 (2212599508) user='coucou'
1d02h: Vi1 AAA/AUTHOR/FSM (2212599508): send AV service=ppp
1d02h: Vi1 AAA/AUTHOR/FSM (2212599508): send AV protocol=ip
1d02h: Vi1 AAA/AUTHOR/FSM (2212599508): found list "dial_in"
1d02h: Vi1 AAA/AUTHOR/FSM (2212599508): Method=radius (radius)
1d02h: RADIUS: framed-route 172.16.0.0 255.255.0.0 192.168.254.1
1d02h: RADIUS: Authorize IP address 172.16.248.254
1d02h: RADIUS: Framed-IP-Netmask 255.255.248.0
1d02h: RADIUS: framed-route 172.16.248.0 255.255.248.0
1d02h: Vi1 AAA/AUTHOR (2212599508): Post authorization status = PASS_REPL
1d02h: Vi1 AAA/AUTHOR/FSM: We can start IPCP
1d02h: Vi1 AAA/AUTHOR/IPCP: Start. Her address 0.0.0.0, we want 0.0.0.0
1d02h: Vi1 AAA/AUTHOR/IPCP: Processing AV service=ppp
1d02h: Vi1 AAA/AUTHOR/IPCP: Processing AV routing*false
1d02h: Vi1 AAA/AUTHOR/IPCP: Processing AV inacl=101
1d02h: Vi1 AAA/AUTHOR/IPCP: Processing AV route=172.16.0.0 255.255.0.0 192.168.2
54.1
1d02h: Vi1 AAA/AUTHOR/IPCP: Processing AV dns-servers=172.16.69.17 172.16.121.17
1d02h: Vi1 AAA/AUTHOR/IPCP: Processing AV wins-servers=172.16.69.20 172.16.121.2
1d02h: Vi1 AAA/AUTHOR/IPCP: Processing AV addr=172.16.248.254
1d02h: Vi1 AAA/AUTHOR/IPCP: Processing AV netmask*255.255.248.0
1d02h: Vi1 AAA/AUTHOR/IPCP: Processing AV route=172.16.248.0 255.255.248.0
1d02h: Vi1 AAA/AUTHOR/IPCP: Authorization succeeded
1d02h: Vi1 AAA/AUTHOR/IPCP: Done. Her address 0.0.0.0, we want 172.16.248.254
1d02h: Vi1 AAA/AUTHOR/IPCP: primary dns server 172.16.69.17
1d02h: Vi1 AAA/AUTHOR/IPCP: primary wins server 172.16.69.20
1d02h: Vi1 AAA/AUTHOR/IPCP: seconday dns server 172.16.121.17
1d02h: Vi1 AAA/AUTHOR/IPCP: seconday wins server 172.16.121.21
1d02h: Vi1 AAA/AUTHOR/IPCP: Start. Her address 0.0.0.0, we want 172.16.248.254
54.1
1d02h: Vi1 AAA/AUTHOR/IPCP: Start. Her address 172.16.248.254, we want 172.16.2
48.254
54.1
1d02h: Vi1 AAA/AUTHOR/IPCP: Done. Her address 172.16.248.254, we want 172.16.24
8.254
1d02h: Vi1 AAA/AUTHOR/PER-USER: Event IP_UP
1d02h: Vi1 AAA/AUTHOR: IP_UP
1d02h: Vi1 AAA/PER-USER: processing author params.
1d02h: Vi1 VTEMPLATE: Has a new cloneblk AAA, now it has vtemplate/AAA
1d02h: Vi1 VTEMPLATE: Clone from AAA
IP access-group 101 in
end
1d02h: Vi1 AAA/AUTHOR: Vaccess parse 'interface Virtual-Access1
' ok (0)
1d02h: Vi1 AAA/AUTHOR: Parse 'IP route 172.16.0.0 255.255.0.0 192.168.254.1'
1d02h: Vi1 AAA/AUTHOR: Parse returned ok (0)
1d02h: Vi1 AAA/AUTHOR: enqueue peruser IP txt=no IP route 172.16.0.0 255.255.0.0
192.168.254.1
1d02h: Vi1 AAA/AUTHOR: Parse 'ip route 172.16.248.0 255.255.248.0 172.16.248.254
1d02h: Vi1 AAA/AUTHOR: enqueue peruser IP txt=no ip route 172.16.248.0 255.255.2
48.0 172.16.248.254
1d02h: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/0:1, changed state t
o up
1d02h: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed
state to up
1d02h: %ISDN-6-CONNECT: Interface BRI1/0:1 is now connected to 0329533045 coucou
NAS_3640_1#
and here an analogue one :
1d02h: %ISDN-6-CONNECT: Interface BRI1/0:1 is now connected to 0329576000
NAS_3640_1#
1d02h: As75 AAA/AUTHOR/FSM: (0): LCP succeeds trivially
1d02h: %LINK-3-UPDOWN: Interface Async75, changed state to up
1d02h: AAA: parse name=Async75 idb type=10 tty=75
1d02h: AAA: name=Async75 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=75 chan
nel=0
nel=1
1d02h: AAA/MEMORY: create_user (0x6156048C) user='coucou' ruser='' port='Async75
' rem_addr='0329576000/9533008' authen_type=CHAP service=PPP priv=1
1d02h: AAA/AUTHEN/START (1518246456): port='Async75' list='dial_in' action=LOGIN
service=PPP
1d02h: AAA/AUTHEN/START (1518246456): found list dial_in
1d02h: AAA/AUTHEN/START (1518246456): Method=radius (radius)
1d02h: RADIUS: Initial Transmit Async75 id 29 192.168.240.2:1645, Access-Request
, len 98
1d02h: Attribute 5 6 0000004B
1d02h: Attribute 3 19 01652D42
1d02h: RADIUS: Received from id 29 192.168.240.2:1645, Access-Accept, len 186
1d02h: Attribute 8 6 AC10F8FD
1d02h: AAA/AUTHEN (1518246456): status = PASS
1d02h: As75 AAA/AUTHOR/LCP: Authorize LCP
1d02h: As75 AAA/AUTHOR/LCP (1184823696): Port='Async75' list='dial_in' service=N
ET
1d02h: AAA/AUTHOR/LCP: As75 (1184823696) user='coucou'
1d02h: As75 AAA/AUTHOR/LCP (1184823696): send AV service=ppp
1d02h: As75 AAA/AUTHOR/LCP (1184823696): send AV protocol=lcp
1d02h: As75 AAA/AUTHOR/LCP (1184823696): found list "dial_in"
1d02h: As75 AAA/AUTHOR/LCP (1184823696): Method=radius (radius)
ied for lcp
lied for lcp
1d02h: As75 AAA/AUTHOR (1184823696): Post authorization status = PASS_REPL
1d02h: As75 AAA/AUTHOR/LCP: Processing AV service=ppp
1d02h: As75 AAA/AUTHOR/LCP: Processing AV routing*false
1d02h: As75 VP: Create and clone from virtual-template 1
1d02h: VTEMPLATE: No unused vaccess, create new vaccess
1d02h: Vi1 VTEMPLATE: Set default settings with no ip address, encap ppp
1d02h: Vi1 VTEMPLATE: Hardware address 0006.d775.d8c1
default ip address
no ip address
encap ppp
enc ppp
encapsulation ppp
end
1d02h: Vi1 VP: Create Virtual Profile for As75
1d02h: Vi1 VP: Bind to As75
1d02h: Vi1 VP: Copied LCP state from As75
1d02h: Vi1 AAA/AUTHOR/FSM (2439018656): Port='Async75' list='dial_in' service=NE
T
1d02h: AAA/AUTHOR/FSM: Vi1 (2439018656) user='coucou'
1d02h: Vi1 AAA/AUTHOR/FSM (2439018656): send AV service=ppp
1d02h: Vi1 AAA/AUTHOR/FSM (2439018656): send AV protocol=ip
1d02h: Vi1 AAA/AUTHOR/FSM (2439018656): found list "dial_in"
1d02h: Vi1 AAA/AUTHOR/FSM (2439018656): Method=radius (radius)
1d02h: RADIUS: Authorize IP address 172.16.248.253
1d02h: Vi1 AAA/AUTHOR (2439018656): Post authorization status = PASS_REPL
1d02h: Vi1 AAA/AUTHOR/IPCP: Set routing to FALSE
54.1
1d02h: Vi1 AAA/AUTHOR/IPCP: Processing AV addr=172.16.248.253
1d02h: Vi1 AAA/AUTHOR/IPCP: Done. Her address 0.0.0.0, we want 172.16.248.253
1d02h: Vi1 AAA/AUTHOR/IPCP: Start. Her address 0.0.0.0, we want 172.16.248.253
54.1
1d02h: Vi1 AAA/AUTHOR/IPCP: Start. Her address 172.16.248.253, we want 172.16.2
48.253
54.1
1d02h: Vi1 AAA/AUTHOR/IPCP: Done. Her address 172.16.248.253, we want 172.16.24
8.253
end
' ok (0)
192.168.254.1
1d02h: Vi1 AAA/AUTHOR: Parse 'ip route 172.16.248.0 255.255.248.0 172.16.248.253
1d02h: Vi1 AAA/AUTHOR: enqueue peruser IP txt=no ip route 172.16.248.0 255.255.248.0 172.16.248.253
state to up
thanks everybody for your helps
philippe
Issue command "sh caller timeout" to see any timeout involved with the dialin users..Also add the command "dialer-list 1 protocol ip permit" in the global config.
Now you can configure the idle timout and absolute timout under the virtual-template 1 to troubleshoot it further..
ppp timeout idle 1800
timeout absolute 180
With that connection should atleast stay connected for 30 mins..
You can also configure those timeouts in radius server for dialin users..
Here is the link which discuss "per user tiemouts" on access server and thru radius server in detail along with troubleshooting.
http://www.cisco.com/warp/public/131/8.html
Thx..Tejal
thaks tejal i tried and i lets you knows
best regards
philippe
p.emery
hi
i have done the test without change after 602 secondes we have a decoonection !!
here is some info :
NAS_3640_1#sh caller timeout
Session Idle Disconnect
Line User Timeout Timeout User in
vty 0 admin - - -
vty 1 admin - - -
BR1/0:1 pme 02:00:00 - 01:58:26
Vi2 pme 01:20:00 00:30:00 00:30:00
13w4d: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BRI1/0, TEI 115 changed to down
13w4d: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/0, TEI 115 changed to down
13w4d: %ISDN-6-DISCONNECT: Interface BRI1/0:1 disconnected from 0329533005 pme, call last
ed 602 seconds
13w4d: %LINK-3-UPDOWN: Interface BRI1/0:1, changed state to down
13w4d: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
13w4d: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/0:1, changed state to down
13w4d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to d
own
router config
timeout absolute 180 0
thanks for your helps it is very important for us !
best regards
philippe
