ACS 5.4. AD Integration attribute Filter-ID retrieve problem
etmarcof
Level 3
Level 3
I have one ACS 5.4  integrated with my AD. And i want to map  Radius IETF Filter-id attribute to a specific  AD group that  AD user belongs.
For exemple i have one AD user: user1 that is member of AD groups:  Domain users group  and Group1.   In this case it works.When i do a Radius Request i can retrieve  attribute Filter-id= Group1
For the same user1  if add them to another AD Group lets says Group2  then  Filter-ID appears empty.
So in summary if an AD user belongs tos  many AD groups i can't retrieve Filter-ID attribute.
Any suggestions to solve this problem?
Best Regards,
MC
pitmacaloway
I have exactly the same problem, did you find the solution?
