Authentication problem with Load Balancers and ACS 4.2 (1) build 15 patch 4
I have an authentication problem with load balancers and ACS 4.2 (1) build 15 patch 4. The load balancers don't register as a fail or pass on the ACS.
I've made an account called aceadmin, and it has unrestricted level 15 commands and it's own shell custom attributes of shell:Admin*Admin default-domain . I've also tried replacing this with shell:Cnt1=admin default-domain
The user group that aceadmin is in has shell customer attributes of cisco-av-pair=shell:roles="network-admin" and shell:Admin*Admin default-domain
Is there anything else we can try regarding the set up on the ACS?
Thanks.
Peter Koltl
Level 7
Level 7
RADIUS VSA/cisco-av-pair or TACACS+ AV-pair?
Peter, the load balancer devices are in a general TACACS+ group with TACACS+ router and switches.
