Cisco ISE Device Administration Prescriptive Deployment Guide
When I want to login to ise 3515 it show disk full and cannot open the GUI.
I would recommend opening a TAC case to address this issue. This is not something we are going to be able to fix via the communities.
5 Replies 5
balaji.bandi
Login on to Console and purge the logs which is not requied.
# show disk
check which directly full
Linux command work in ISE too du -k command over the resultant directory
in to the folder delete old logs which is not required.
BB
SIR BUT HOW TO LOGIN TO CONSOLE .WHEN TRY TO LOGIN IT SHOW DISK FULL
sir
thanks for help. When try to login from the console it show following error "unable to launch ADE-OS SHELL ,DISK FULL"
I was in impression you were not able to login only web gui, if you also have console / shelll access issue.
suggested to open a TAC case for support.
BB
