cisco ISE Guest Web authentication doesn't work with SG300 switch
Qays
I used cisco SG300 switches as access switch and I trying to use cisco ISE as NAC, I have configured the switches and the ISE, the authentication and authorization works for the Active Directory users, but the Guest web users authentication doesn't work, I have configured every thing as the documentation.
Is the problem in the switch doesn't support COA and DACL ???
Thanks...
2 Accepted Solutions
marce1000
- The SG seems not supported by ISE :
           https://www.cisco.com/c/en/us/support/security/identity-services-engine/products-device-support-tables-list.html
 M.
 - That depends on your Intranet's network 'power needs' for a generic start go here :
             https://www.cisco.com/c/en/us/products/switches/switch-selector.html
 (but keep an eye on the ise compatibility matrix as posted earlier).
 M.
5 Replies 5
marce1000
 M.
Thanks for the answer......
Could you advise me which series of access switches that  I should use...
Thanks,,,,,
 M.
OK ,,, Thanks
