CISCO MAB Auth for Wireless devices
henokk60
Hi All
I want to configure MAB authentication for wireless users. The same SSID is used for 802.1X, and I would like to use MAB for specific users. Is that possible, and how can I achieve it?
Same SSID have both 802.1x and mab' I dont think it work
For new SSID using MAB' you can use
Local mac authc
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213922-configure-mac-authentication-ssid-on-cis.html
MHM
balaji.bandi
yes its possible, depends on what controller you using the configuration need to look their documentation.
Good video how you can configure on ISE :
ISE deployment :
https://community.cisco.com/t5/security-knowledge-base/ise-secure-wired-access-prescriptive-deployment-guide/ta-p/3641515
https://www.youtube.com/watch?v=PRlLDhbljIE
BB
Not possible. You can do 802.1X with MAC address conditions but not both. What is the use-case? What is the access method for MAB? PSK? Something else? open?
