01-02-2018 11:05 PM - edited 03-11-2019 01:16 AM
Is there any guide available for hardware 3650 , ASA5525X & CAT9300 stating IP-SGT mapping limitation.
On ISE side we have a 150000 limitation per SXP node. Do we have something same on Hardware side as well while hardware is downloading the IP-SGT mapping.
For ISE i checked the below doc
Solved! Go to Solution.
01-03-2018 01:47 AM
Hi Raghav,
the IP-SGT mapping limits per platform are documented at the bottom of the TrustSec system bulletin, the latest being version 6.3:
12k for the 3650
10k for the 9300
You'll get up to about 400k on the ASA 5525x
Regards, Jonothan.
01-03-2018 12:28 AM
I have moved your query to the TrustSec community TrustSec
01-03-2018 01:47 AM
Hi Raghav,
12k for the 3650
10k for the 9300
Regards, Jonothan.
