Do we have any hardware limitation for IP-SGT mapping number?
raghchan
Is there any guide available for hardware 3650 , ASA5525X & CAT9300 stating IP-SGT mapping limitation.
On ISE side we have a 150000 limitation per SXP node. Do we have something same on Hardware side as well while hardware is downloading the IP-SGT mapping.
For ISE i checked the below doc
ISE Performance & Scale
jeaves@cisco.com
Hi Raghav,
the IP-SGT mapping limits per platform are documented at the bottom of the TrustSec system bulletin, the latest being version 6.3:
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise-networks/trustsec/software-system-bulletin.pdf
12k for the 3650
10k for the 9300
You'll get up to about 400k on the ASA 5525x
Regards, Jonothan.
ldanny
I have moved your query to the TrustSec community TrustSec
jeaves@cisco.com
Hi Raghav,
12k for the 3650
10k for the 9300
Regards, Jonothan.
