Meraki APs not connecting
HAT
Hi All
I m setting a new Network for one of our remote sites and looking to add some  Meraki access points for Wifi connectivity . These were initially used for a different site and getting re purposed for the new place . The APs are being managed through the Meraki Cloud platform .
The APs are currently connected to a Cisco switch ( 2960 X ) via a trunk link carrying the following Vlans.
2 : Corporate SSID
3 : AP Management Vlan ( Native )
5 : Guest Vlan SSID
The switch is turn trunked to a Firewall ( acting as a DHCP server ) that has also been configured to carry the above Vlans. Internet reachability has been confirmed and the correct policies are in place to allow the APs to check into Meraki Cloud.
After connecting the APs into the switch , they don t seem to be able to obtain an IP address from the firewall although other devices ( ie my laptop) can , nor can the firewall see them on the ARP table .
The light on the APs is currently showing amber .
This is the config applied to one the the switch ports
interface GigabitEthernet1/0/2
description AP
switchport trunk native vlan 3
switchport trunk allowed vlan 2,5
switchport mode trunk
storm-control broadcast level 10.00
storm-control multicast level 10.00
Can you please advise on what could be the issue here ?
Please find below the topology of the network setup
Thanks in advance
did you created VLAN interfaces in correct physical port in firewall? is DHCP tested? is switch port from switch to firewall configured with correct vlan allow list? are you getting DHCP IP address if you connect laptop to another switch port and configure that as access vlan with correct vlan?
Good luck
KB
HAT
The management AP was not allowed into the "Allow" list over the trunk . Thanks All
connect the Laptop and check - also try check with static IP see you able to ping Gteway.
looks for me whomething missing, so post Switch show run  full.
is the FW acting as DHCP, did you getting any request.
BB
