Parsing logs to remote destination(FTP) from Cisco Secure ACS 5.X
network_geek
Hi All,
Although this device is an older one but I still feel some people might be working on them. I need your guidance in achieving the following:
All Accounting Logs of users(all commands entered) are to be transferred after a specific interval to remote destination: I have either an FTP server or I can have a machine used for storage purposes only.
Can someone please share step by step guide?
Any information in this regards will be highly appreciated.
6 Replies 6
balaji.bandi
you may find option here :
System Administration > Log Configuration > Remote Log Targets > Create to set the IP address of the remote log server.
also attached one archive document from my hdd.
BB
Hi Balaji,
Please refer to attached screenshot taken from ACS. Moreover, I can confirm reachability b/w ACS and FTP. Lastly, would you need further outputs that might aid you.
ping A.B.C.D (A.B.C.D) 56(84) bytes of data.
64 bytes from A.B.C.D: icmp_seq=1 ttl=61 time=0.636 ms
64 bytes from A.B.C.D: icmp_seq=2 ttl=61 time=0.639 ms
64 bytes from A.B.C.D: icmp_seq=3 ttl=61 time=0.650 ms
64 bytes from A.B.C.D: icmp_seq=4 ttl=61 time=0.525 ms
network_geek
Hi Balaji,
Thank you for your update. I have configured the repository. Now when will I get to see the accounting logs on the remote server? Can I specify a period as well?
balaji.bandi
if the path is correct they pushed automatically check on the remote server.
BB
Hi Balaji,
It shows me all the contents of remote server from ACS as explained in the guide but still nothing was saved in the remote server whatsoever. I think not many people have worked on this particular scenario.
Can you post the screenshot and configuration? (whatever you can provide)
do you have reachability from ACS to the destination server?
BB
