Problem Adding subnets in a Network Device Client
Alexis Clavero
Visitor
I have a problem trying to add a Network Device  in my ACS 5.4 using a CSV file. The problem is:
2013-11-04 10:33:39: File Format Validation Completed
2013-11-04 10:33:39: Import Started
2013-11-04 10:33:39: Record number: 1, Network Device Rango_Gestion: Import Failed
2013-11-04 10:33:39: null Import process failed for unexpected reason: Unknown error has accurred.
2013-11-04 10:33:39: Record number: 2, Network Device Rango_Gestion: Import Failed
2013-11-04 10:33:39: Record number: 3, Network Device Rango_Gestion: Import Failed
2013-11-04 10:33:39: Record number: 4, Network Device Rango_Gestion: Import Failed
2013-11-04 10:33:39: Import Completed With errors
-------- Summary --------
Total Number of Records Processed:1
Number of Records Failed:4
Number of Records Imported:0
---------- End ----------
Please refresh the table to see the changes.
I tried to add manually the same subnets in the :
10.2.26.1-162;10.2.26.171-204;10.2.26.207-254;10.25.5.142-143;10.25.5.153;10.2.20.4;10.2.1.3;10.6.3.3;10.2.15.13;10.7.3.10;10.6.3.6;10.2.1.98;10.25.5.146;10.64.8.1;10.6.3.7-8;10.2.1.79-80;10.2.1.27-28;10.2.1.181;10.6.5.4;10.25.5.150;10.25.100.140;10.2.27.1-9;10.2.27.31-254;10.25.200.106;10.2.22.100-101;10.6.25.4;10.55.0.*
and it appears the next message:
This System Failure occurred: Index: 0, Size: 0. Your changes have not been saved.Click OK to return to the list page.
This message appears when I try to add th subnet number 24 (If i try to add only 23 subets works properly).
Anybody hava any idea about the problem?
Thanks!
PD: I've been working with two appliances (SNS-3415) and the problem is te same for both.
edwjames
Level 8
Level 8
Hi Alexis,
Do you mind sharing the CSV file?
**Share your knowledge. It’s a way to achieve immortality.
--Dalai Lama**
Please Rate if helpful.
Ed
**Share your knowledge. It’s a way to achieve immortality. --Dalai Lama** Please Rate if helpful. Regards Ed
