Problem with ACS authenticate Accounts
alforkanehafid
Hi all,
I have ACS version 5.1.0.44.and WLC version7.
already I create new database in ACS Local and I integrate the ACS with AD to use the local and AD simultaneously.
Now,all the users can authenticate to wired and wireless devices
The issue is that I need to separate the accounts to permit users using wireless to authenticate with AD accounts and wired users to authenticate using Local accounts.
thank you in advanced.
warm regards
Hafid Alforkane
5 Replies 5
edwjames
Level 3
Level 3
Groups the switches into one NDG and WLCs/APs into another.
In  the identity section under the access service, create rules based on  NDG device type and assign respective databases as results.
**Share your knowledge. It’s a way to achieve immortality.
--Dalai Lama**
Please Rate if helpful.
Ed
**Share your knowledge. It’s a way to achieve immortality. --Dalai Lama** Please Rate if helpful. Regards Ed
thank you very much for your response.
just i need the step and the screan for configuration.
many thanks for you help.
Best regards
Hafid Alforkane
edwjames
Level 3
Level 3
Do you need screenshots, you mean ?
or have you figured it out?
--Dalai Lama**
Ed
Hi Edward;
Many thanks for your help.
Yes, i need screenshots, step by step.
Thanks a lot.
Best regards
Hafid Alforkane
Few screens that should guide you:
--Dalai Lama**
Ed
