Bookmark
Subscribe
4459
Problem with portal guest Cisco ISE
andres.salesa1
We just installed Cisco ISE 2.2 patch2.
Version 2.2.0.470
Installed Patches 1,2
Product Identifier (PID) ISE-VM-K9
Version Identifier (VID) V01
ADE-OS Version 3.0.2.218
We have the basic/wired license (no posture and no profiling)
Access to the guest portal is done with a username and password and we create them through the sponsor portal.
When an external guest client tries to access the guest portal. The portal asks the guest user to install the latest version of Java.
Is it normal behavior? Do I need to have java? It is not feasible for all external users to have the JAVA version to access an invited portal.
This happens in Windows 7 and Windows 10 environments with the latest versions of IE, Mozilla and Chrome.
Can somebody help me?
thank you
Go to your portal open settings there and find :
6 Replies 6
Arne Bier
Hi Andres
Do you have some screenshots of this happening?
Your deployment sounds almost identical to mine.  There is no requirement for Java on the client side - it's just HTML that gets presented to the end device.  I have connected MACOS , Win7 through 10, Android Phones (no Java), Apple Phones (no Java).
Are you sure this is triggered by ISE, or by the client's OS ?
The ISE Admin GUI requires Adobe Flash for a few functions and you will be prompted for that.  But even that doesn't require Java on the client side.  There may be some Java Script that runs in the browser but to my knowledge that does not require you to install the JRE from www.java.com
If anything, rest assured that since Apple iOS does NOT run Java, they connect just fine to an ISE Guest Portal
Hi Arne,
I have attached some screenshots.
Even installing the latest version of java 8. Continue requesting Java installation with all browsers (Mozilla, Chrome and IE)
The problem comes through the guest portal. Users who leave this message have no problem to navigate or perform their tasks.
I tested it with Android phones and Iphone. And we can access the portal and navigate without problems. Do not request anything additional.
Java should not be mandatory. Being new to the tool and newly installed. I do not know, if it is something normal, a bug, etc.
Did you check your guest portal and see if its requiring compliance or BYOD? If it is uncheck that.
Excuse my ignorance. I have the base license.
The option to require compliance can not be found by any menu option. I am not clear that these options go with my license.
Could you tell me where I can locate this option?
Hi have ISE 3.1.0.518 and i have this issue too and this solution do not work for me.
Someone can help me please
