Problems with Nac Download and checking
jtimmer1
We're deploying ISE, and i am busy with deploying a portal that Domain users can install they own NAC client.
however, we are facing issues with that.
When i am using a ise configured laptop, they cannot access the ISE Server by hostname.
When i using a non ise configured laptop, i can access the Server. and download the NAC agent. After installation the NAC agent get's an timeout and stops.
Also when the agent is installed, they will try to install it again.
See below for the switchconfig and the dACL
DACL:
permit udp any any eq 53
permit tcp any any eq 53
permit udp any eq bootpc any eq bootps
permit tcp any host 10.23.14.12 eq 8443
permit tcp any host 10.23.14.12 eq 8905
permit udp any host 10.23.14.12 eq 8905
permit tcp any host 10.23.14.12 eq 8906
permit udp any host 10.23.14.12 eq 8906
permit tcp any host 10.23.14.12 eq 8909
permit udp any host 10.23.14.12 eq 8909
permit ip any host 10.23.14.12
permit ip any host 10.22.40.1
deny ip any any
SWITCHCONFIG
aaa group server radius ISE
 server name ISE
aaa authentication login default group nps-radius local
aaa authentication dot1x default group ISE
aaa authorization network default group ISE
aaa accounting dot1x default start-stop group ISE
aaa server radius dynamic-author
 client 10.23.14.12 server-key
dot1x system-auth-control
interface FastEthernet0/1
 switchport mode access
 switchport voice vlan 319
 ip access-group permitany in
 authentication host-mode multi-domain
 authentication order mab dot1x
 authentication priority dot1x mab
 authentication port-control auto
 authentication periodic
 authentication timer reauthenticate server
 mab
 dot1x pae authenticator
 dot1x timeout tx-period 10
 spanning-tree portfast
interface Vlan113
 ip address 10.22.2.240 255.255.255.0
ip default-gateway 10.22.2.1
ip http server
ip http secure-server
ip http secure-active-session-modules none
ip http active-session-modules none
ip access-list extended REDIRECT
 deny   udp any any eq domain
 deny   tcp any any eq domain
 deny   udp any eq bootpc any eq bootps
 deny   tcp any host 10.23.14.12 eq 8443
 deny   tcp any host 10.23.14.12 eq 8905
 deny   udp any host 10.23.14.12 eq 8905
 deny   udp any host 10.23.14.12 eq 8906
 deny   tcp any host 10.23.14.12 eq 8906
 deny   tcp any host 10.23.14.12 eq 8909
 deny   udp any host 10.23.14.12 eq 8909
 deny   ip any host 10.23.14.12
 permit ip any any
ip access-list extended permitany
 permit ip any any
ip radius source-interface Vlan113
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius server ISE
 address ipv4 10.23.14.12 auth-port 1812 acct-port 1813
 key
kvenkata1
Please follow the posture service guide, specifically the troubleshooting section to isolate/identify your issue.
https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine/116143-config-cise-posture-00.html
- Krish
kvenkata1
- Krish
paul
Level 10
Level 10
Why are you using the client provisioning portal to install the posture module/NAC agent?  You should be using SCCM or whatever software management tool you use.  Using the client provisioning portal to install is going to cause confusion later and potential issues because of the redirect.
Hallo Paul.
Thanks for your reply.
We've doing a Proof of concept. So we checking all the features en what works for our company.
For now we want to do the provisioning portal. But for later production use. W e want to do it by sccm.
Also our thin clients are not domain joined.
That is why we want to use the portal.
