URL Redirection on Wireless Client Machine Fails
Tabish Mirza
Wireless users athenticated by ISE internal identity but unable to redirect on URL.
5 Replies 5
andrewswanson
Level 7
Level 7
hello - your pdf link is for external web authentication - the link below shows how to configure ssid layer 3 security for url redirect
hth
andy
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080956185.shtml
Hi. First of all thanks for your reply.
By mistake I have attached above pdf.
Let me explain my scenario. WLC is integrated with ISE & ISE is integrated with AD. We have wireless users (not a guest wireless users) who has to go through the ISE process before gonna access the network. These domain users is successfully authenticating by the AD through WLC & ISE. Once the domain users authenticate they have to redirect to URL while accessing any website through browser but it is not happening.
Moreover, could you please help me that how to configure posture condition for AV & WSUS. Do you have any doc to configure following requirement & apply to profile.
The "URL-redirect.jpg"  shows that you're redirecting to ISE Guest portal. The URL is "bahugb-ise-admin.gib:8443/guestportal".
Why would you want to redirect to ISE Guest portal if you mentioned the users are already authenticating with Active Directory ? Could you please post your Wireless Lan configuration to understand a little more ?
myanuary
@eduardo, maybe he want to use CoA that used in ISE..
@Mirza, can you post configuration/screenshoot Layer 2,AAA,and Advanced tab
on your WLAN ?
and what is the full redirection URL that you get on WLC ?
i think on acces list you must allow DNS..
