WiFi Issue with Cisco NAC Agent....!!!
Nithin Jacob
Cisco  NAC Agent is configured for a user laptop in one of the campuses. Wifi  is working perfectly fine for a partcicular SSID ( eg: SSID-X) , in the  Office areas, but when the user moves to his residence, its gets  disconnected and fails to work ( for the SSID-X)
But when the user  tries connecting to other SSID's, it gets connected and works normally.
Is there any problem on the controller, or is there something missing.
Can anyone please guide me to a solution for the problem...????
Amjad Abdullah
It is only one controller? It is possible the access point in user's resident is joining a different controller.
What the exact message the user get when he tries to connect and fails?
What is your controller model/version?
Any logs on the NAC server for the user mac address?
Amjad
Rating useful replies is more useful than saying "Thank you"
Hi Amjad,
There are 3 different controllers. Two Cisco 4404 controllers with versions V02 & V04 & a Cisco WISM2 controller with a version of V01.
When a user tries connecting to the particular SSID, in the residence areas , it says that
"Windows is unable to connect to SSID-X" . But it works fine in the office areas.
Nithin.
Hi Nithin,
"Windows is unable to connect...." message appears on the client, right?
What appears on the NAC server logs?
