08-02-2011 09:13 AM
Our CiscoWorks server disk utilization is very high. Our C: drive is 64GB hard disk and Ciscoworks is installed on this drive, currently this disk is used up to 90%. When we do manual log rotate (as automatic not working) to another drive E and then C drive reduces to 85% but still very high. On the same server our E drive is 136 GB and currently 111GB is free.
Is it possible to completely move the CiscoWorks installation from C to E drive?
We have currently 3000 logical devices configured on server. Please advice the safest way so that we can have CW on the server by bigger drive i.e. E
We are currently using the LMS 3.2, RME.4.3.0, and CM 5.2.1
Solved! Go to Solution.
08-02-2011 12:31 PM
In short
Take backup
Uninstall (clean_system.exe)
reinstall on new drive
restore backup
Cheers,
Michel
08-02-2011 12:31 PM
In short
Take backup
restore backup
Cheers,
Michel
