11-10-2018 06:29 PM
Hello All,
I've recently purchased a few 1841 routers for a home lab while I study for my CCNA. The routers were purchased off of eBay, and all of them were locked and requiring login before getting to a command line.
I was hoping it would be as simple as putting the CF cards in a reader, wiping them, and transferring a fresh BIN.
After doing that I get the error:
loadprog: bad file magic number: 0x0
boot: cannot load "flash:"
So then I tried to load the BIN via TFTP.
My first attempt was with TFTP64, I would continually receive the error:
Ack block 65535 ignored (received twice)
TIMEOUT waiting for Ack block #65536
I then tried Solarwinds with a similar result:
Dropped because peer didn't respond
These failures happened repeatedly, with different Ethernet cables to isolate any other possibilities of failure.
Any help is appreciated as I'd just like to get these up and running to continue my studies. Thank you!
11-10-2018 08:51 PM
1. Check the MD5 hash value on of downloaded file (BIN) on your system before uploading to the router and match it on the Cisco website.
2. Disable Antivirus and firewall on your laptop/desktop.
3. check for any ping Drop from the router to laptop.
If the MD5 hash value is mismatch than you have to download the same file again.
Deepak Kumar
11-11-2018 10:01 AM
11-10-2018 09:42 PM - edited 11-10-2018 10:52 PM
This error message means the the router is trying to read a corrupt IOS.
Console into the router and reboot. Post the entire boot-up process.
11-11-2018 10:00 AM
System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 processor with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xc100
Initializing ATA monitor library.......
PLD version 0x10
PLD version 0x10
rommon 1 >
Thanks!!
11-12-2018 12:24 AM
looks to me like you copied the bin for another model router to the flash card.
you said you have multiple routers? do you still have "working" device (locked but booting normal)
you can get the bin off that CF card and put it on another?
and try this to wipe the config only and not the whole flash
Password Recovery Procedure for the Cisco 1700 and 1800 Series Routers
11-12-2018 07:40 AM
The router that is booting is pulling up this lock screen:
program load complete, entry point: 0x8000f000, size: 0x2c3fe90
Self decompressing the image : ########################################################################################################################################################################################################################################################################## [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X003AA110 public buffer pools
0X00211000 public particle pools
0X00020000 Crypto module pools
0X0052 0X0001A800 Card in slot 0
0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 13176105 bytes to IO Memory.
PMem allocated: 245366784 bytes; IOMem allocated: 23068672 bytes
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-ADVENTERPRISEK9-M), Version 15.1(3)T3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 14-Dec-11 20:21 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Installed image archive
Cisco 1841 (revision 6.0) with 239616K/22528K bytes of memory.
Processor board ID FTX1005Y23V
2 FastEthernet interfaces
1 Serial interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
255488K bytes of ATA CompactFlash (Read/Write)
ip nbar port-map sqlserver tcp 1433 5000
% Invalid input detected at '^' marker.
Press RETURN to get started!
*Nov 12 16:03:55.443: SERVICE_MODULE(Serial0/0/0): self test finished: Passed
*Nov 12 16:04:23.035: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Initialized
*Nov 12 16:04:23.039: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Enabled
*Nov 12 16:04:25.247: %LINK-3-UPDOWN: Interface Serial0/0/0, changed state to down
*Nov 12 16:04:26.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Nov 12 16:04:26.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0, changed state to down
*Nov 12 16:04:26.815: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*Nov 12 16:04:27.607: %SYS-6-CLOCKUPDATE: System clock has been updated from 16:04:27 UTC Mon Nov 12 2018 to 11:04:27 EST Mon Nov 12 2018, configured from console by console.
*Nov 12 16:04:27.611: %SYS-6-CLOCKUPDATE: System clock has been updated from 11:04:27 EST Mon Nov 12 2018 to 11:04:27 EST Mon Nov 12 2018, configured from console by console.
*Nov 12 16:04:28.211: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
*Nov 12 16:04:42.795: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, changed state to up
*Nov 12 16:04:44.003: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
*Nov 12 16:04:45.079: %SYS-5-CONFIG_I: Configured from memory by console
*Nov 12 16:04:45.315: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Nov 12 16:04:49.595: %SYS-5-RESTART: System restarted --
*Nov 12 16:04:49.599: %SNMP-5-COLDSTART: SNMP agent on host Omaha_077 is undergoing a cold start
*Nov 12 16:04:49.923: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Nov 12 16:04:49.947: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Nov 12 16:04:49.951: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Nov 12 16:04:49.951: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Nov 12 16:04:49.951: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFFC
/ _ _ \
+----oOOO------( )--------------+
| This is a private system. |
| You are not welcome. Go away. |
| Authorized access only. You |
| will be prosecuted to the |
| extent of the law. Everything |
| is logged and privacy is not |
| guaranteed. |
+-----------------------oOOO----+
|__| |__|
(__| |__)
User Access Verification
Username:
11-12-2018 08:09 AM - edited 11-12-2018 08:14 AM
that looks al right!
the router is loading the firmware and is loading the config, so ths is operational.
it is running
is this also the software you put on the flash card with use of the the card-reader?
if so, how did you wipe the card? did you format as fat ?
for this router start the password recovery procedure as described in the link.
in this proces you will
1) interrupt the normal boot to get into rommon
2) set a config register to NOT load the config
3a) if password recovery is enabled you can continue boot
and do a manual "write erase" to clear the config and clear the account to login
3b) if password recovery is disabled you are prompted to clear the config before boot continues
in both cases you will have a working router with an empty config and continue with a clean can start
11-12-2018 09:00 PM
11-12-2018 09:30 PM
Just to add- I used the router itself to format the CF card, then used a PC to copy the bin from the working router to the router that only boots to ROMMON. Still will not boot with the error:
System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
Initializing cache
Initializing TLB and required TLB entries
Reading monitor variables from NVRAM
Init Rommon Upgrade NVRAM Vars
Init Rommon Upgrade startPLD version 0x10
Reset IO
Enabling interrupts
Reading cookie
Initializing main memory
Sizing NVRAM
Initializing PCI subsystem
Exiting init
rommon 1 >
11-12-2018 11:48 PM - edited 11-13-2018 02:56 AM
<edited because of some mistakes>
you've got a running router with 15.1(3)T3
and a faulty running Version 12.3(8r)T9
NB! sizes looks similar, at first sight but Flash and RAM size must be sufficient for this specific IOS version.
My guess is the 12.3(8r) version is faulty in some way.
I suggest you copy the 15.1(3)T3 to the other flash card(s)
either you can do this by cardreader
or you can upload this IOS from the operational router to the TFTP server
copy flash:.... tftp:
and then download it to the other router from rommon
11-13-2018 07:37 AM
Pieterh, thank you for the help. I was able to get the running routers bin downloaded via TFTP.
When trying to upload the bin to the other routers I still get the same error:
Connection received from 169.254.43.3 on port 27780 [13/11 08:20:41.129]
Read request for file <c1841-adventerprisek9-mz.151-3.T3.bin>. Mode octet [13/11 08:20:41.129]
Using local port 58123 [13/11 08:20:41.129]
Ack block 65535 ignored (received twice) [13/11 08:29:06.594]
TIMEOUT waiting for Ack block #65536 [13/11 08:29:53.010]
When copying the bin directly to flash via card reader I get this error on boot: (CF was formatted in FAT)
PLD version 0x10
PLD version 0x10
PLD version 0x10
rommon 1 >
Thanks again, you've been a huge help.
11-14-2018 12:11 AM
3. If you are still in ROMmon, that means your boot image is either missing or corrupted. If your router has no valid image in Flash or Bootflash, and no other ROMmon upgrade procedure, the only way to recover is to have a similar router with a compatible Flash card, download the image on that router, and then move the Flash card to the one that is stuck.
there are several ways to resolve this
rommon 1 > tftpdnld -r
Note The -r variable is optional. Entering this variable downloads and boots the new software but does not save the software to flash memory. You can then use the image that is in flash memory the next time you enter the reload command.
could you try the command above?
if this loads you've got a running IOS from where you have more options to troubleshoot the flash
alternatively you can reinitialize the faulty flash using the working router
- you can safely remove the good flash (mark it!)
- insert the faulty flash
- dowload the image from tftp again
11-14-2018 09:48 PM
