2911 router - Netflow V5 through GRE Tunnels
Gurjinder Judge
Hi All,
Does the 2911 router support the ability for Netflow V5 to pass through GRE tunnels? I can't seem to find any documentation that indicates this.
Gurjinder
John Blakley
Netflow is supported on GRE tunnels....
http://www.cisco.com/en/US/docs/ios/solutions_docs/netflow/nfwhite.html#wp1031616
HTH,
John
HTH, John *** Please rate all useful posts ***
Don Jacob
If you are going to use a GRE tunnel as the flow export interface from the router exporting NetFlow, it will not work. Cisco bug IDs for this issue are CSCsk25481 and CSCef28662 and is applicable to both traditional and flexible NetFlow.
To allow NetFlow export from a device through an encrypted tunnel on the same device, enable Flexible NetFlow and use the command output-features when configuring your flow exporter. That will allow NetFlow export over encrypted tunnels.
Don Thomas Jacob
http://www.solarwinds.com/netflow-traffic-analyzer.aspx
NOTE: Please rate posts and close questions if you have found the answers helpful.
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
