03-25-2009 09:13 AM
I am running LMS2.6 on Solaris 9. I have CS 3.0.6, RME 4.0.6, DFM 2.0.12 and CM 4.0.12 installed. It shows the module type in Device Center, but when I try to use CiscoView, error displayed stating that "device package not found" Do I have to install IDU's to get the device to show up in CiscoView? Thanks for the help.
Solved! Go to Solution.
03-25-2009 01:43 PM
CiscoView device packages can be downloaded from http://www.cisco.com/kobayashi/sw-center/netmgmt/ciscoview/cvcww-download.shtml. You can then install them using the LMS Software Center interface of the PSUCli command line tool.
03-25-2009 11:11 AM
What is the sysObjectID of this switch?
03-25-2009 11:32 AM
Will get that info. Hold one
03-25-2009 11:34 AM
1.3.6.1.4.1.9.1.910
03-25-2009 11:36 AM
This switch is supported in CiscoView CBS31x0 package version 2.0. You can download this via Common Services > Software Center > Device Update.
03-25-2009 01:19 PM
Thanks! My server is not connected to the internet. So that explain why my other Ciscoworks server cannot display the 7606-S. Is there anyway to get these patches. Again, many thanks!
03-25-2009 01:43 PM
