3110G switch for IBM blade server "device package not found"
didentx01
I am running LMS2.6 on Solaris 9. I have CS 3.0.6, RME 4.0.6, DFM 2.0.12 and CM 4.0.12 installed. It shows the module type in Device Center, but when I try to use CiscoView, error displayed stating that "device package not found" Do I have to install IDU's to get the device to show up in CiscoView? Thanks for the help.
CiscoView device packages can be downloaded from http://www.cisco.com/kobayashi/sw-center/netmgmt/ciscoview/cvcww-download.shtml. You can then install them using the LMS Software Center interface of the PSUCli command line tool.
6 Replies 6
Joe Clarke
What is the sysObjectID of this switch?
Will get that info. Hold one
1.3.6.1.4.1.9.1.910
This switch is supported in CiscoView CBS31x0 package version 2.0. You can download this via Common Services > Software Center > Device Update.
Thanks! My server is not connected to the internet. So that explain why my other Ciscoworks server cannot display the 7606-S. Is there anyway to get these patches. Again, many thanks!
