3650 managment interface reachable without default route
Mike Assel
Level 4
Level 4
I have a 3650 where remote access to the management interface is working and I can't figure out why. I configured an IP address on the management interface, but with no default route or default gateway configured, I'm able to access the switch from a remote subnet. I don't see why this is working. Can anyone educate me?
Running Config
Current configuration : 8830 bytes
! Last configuration change at 12:34:43 UTC Tue Jul 16 2019 by cisco
version 16.9
no service pad
service call-home
no platform punt-keepalive disable-kernel-core
hostname 3560-2
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5 $1$pz4F$eB1bizmoP1kV1bNgPItsH0
no aaa new-model
switch 1 provision ws-c3650-24pdm
call-home
 ! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
 ! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
 contact-email-addr sch-smart-licensing@cisco.com
 profile "CiscoTAC-1"
  active
  destination transport-method http
  no destination transport-method email
ip dhcp pool webuidhcp
login on-success log
ipv6 unicast-routing
vtp mode off
license boot level ipbasek9
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
redundancy
 mode sso
transceiver type all
 monitoring
vlan 11
 name DANTE
vlan 13
 name AVB
vlan 22
 name EXTERITY
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 ip address 10.1.150.6 255.255.255.0
 speed 1000
 negotiation auto
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
 ipv6 dhcp client request vendor
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
 no ip address
 shutdown
iox
ip forward-protocol nd
ip http server
ip http secure-server
ip http client source-interface GigabitEthernet0/0
ip tftp source-interface GigabitEthernet0/0
control-plane
 service-policy input system-cpp-policy
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login local
 length 0
line vty 5 15
 login
app-hosting appid guestshell
 app-vnic management guest-interface 0
end
Seb Rupik
Hi there,
Sounds like the router on the management subnet is configured to perform proxy-ARP:
https://www.cisco.com/c/en/us/support/docs/ip/dynamic-address-allocation-resolution/13718-5.html
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
balaji.bandi
Management Interface configured as L3 configuration, can you give example ? what is the remote address example IP ?
can you also let us know where is this remote IP address located in the network ?
BB
