3750 Express setup problems
wnking01
Visitor
I have a Catalyst 3750.  When I am in Express setup and open a browser to 10.0.0.1 I get the screen Telnet to the Router, Show Interfaces, Show Diagnostic Log, Monitor the Router, Show Tech Support, Extended Ping and ends with Web Console.  I thought that when I typed in 10.0.0.1 I was supposed to go into the Express Setup page.  When I click on the Web Console - Manage the Switch through the web interface, I get 404 not found error.  Also, the path is 10.0.0.1/homepage.htm
Mark Elsen
 - The device needs to be installed with a software package containing the web based dev management bundle (usually a tar file). not simple-bin only, check cisco downloads for the particular model and install accordingly.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark Elsen
 M.
Thank you I will try that.
