4900 switches Support on LMS 3.1
Hisham_IBM
Dears,
Please I need to know if Cisco Works LMS 3.1 can support 4900 switches series or not?
Joel Monge
LMS 3.1 does support some 4900 models.  See below link for supported device table:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.1/device_support/table/lms31sdt.html
However, if you are going with LMS 3.x, you should be looking for LMS 3.2.1 which is the latest version you can upgrade to without a 4.x license.  Supported device table for LMS 3.2 can be found here:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/device_support/table/lms32sdt.html
Joel Monge
Thank you Monge !!!!
