9800 Redundancy error.
CCC3
Level 5
Level 5
I am trying to duplicate two C9800-40-K9 units.
I followed the guide properly
Connect RP and over time
*Oct 28 05:13:31.502 KST: %IOSXE_REDUNDANCY-6-PEER_LOST: Active detected chassis 2 is no longer standby
*Oct 28 05:13:31.509 KST: %IOSXE_PEM-6-REMPEM_FM: Power Supply/Fantray module Chassis 2 slot P0 removed
*Oct 28 05:13:31.513 KST: %IOSXE_PEM-6-REMPEM_FM: Power Supply/Fantray module Chassis 2 slot P2 removed
*Oct 28 05:13:31.584 KST: %REDUNDANCY-3-STANDBY_LOST: Standby processor fault (PEER_NOT_PRESENT)
*Oct 28 05:13:31.584 KST: %REDUNDANCY-3-REDUNDANCY_ALARMS: Unable to assert REDUNDANCY alarm
*Oct 28 05:13:31.584 KST: %REDUNDANCY-3-STANDBY_LOST: Standby processor fault (PEER_DOWN)
*Oct 28 05:13:31.584 KST: %REDUNDANCY-3-STANDBY_LOST: Standby processor fault (PEER_REDUNDANCY_STATE_CHANGE)
*Oct 28 05:13:31.499 KST: %STACKMGR-6-STACK_LINK_CHANGE: Chassis 1 R0/0: stack_mgr: Stack port 2 on Chassis 1 is down
*Oct 28 05:13:31.500 KST: %STACKMGR-6-STACK_LINK_CHANGE: Chassis 1 R0/0: stack_mgr: Stack port 1 on Chassis 1 is down
*Oct 28 05:13:31.500 KST: %STACKMGR-6-CHASSIS_REMOVED: Chassis 1 R0/0: stack_mgr: Chassis 2 has been removed from the stack.
*Oct 28 05:13:33.470 KST: %RF-5-RF_RELOAD: Peer reload. Reason: EHSA standby down$chassis active R0 rmi-connection-details
The peer is infinitely reloaded along with the log.
The version is version 17.9.3.
what's the reason?
Leo Laohoo
Post the complete output to the command "sh chassis rmi".
